Case Jx95
/ Case Jx95 #1
Chris Christopher
Case Jx95
I have a Case Jx 95 that I have replaced the steering fluid tank 3 times and after I replace it everything works great and then the tank will melt and loose all my fluid. Why is this thing melting my tanks.
/ Case Jx95 #2
Heat or not rated for the fluid are first things suspect.
Is it close to something hot?
Does the melting start one place?
Is your steering fluid boiling? If it is the fluid heat you can add a cooler.
/ Case Jx95
Yes it is close to manifold and I was thinking about adding some heat shield . Just wasn’t sure if that was the problem or fluid boiling.
/ Case Jx95 #4
Get an infra-red thermometer (~$20 at Harbor Freight) and see what is causing your problem. I doubt it's the steering fluid. Sounds more like it would be exhaust related. Look for exhaust leaks like the line to the turbo, proximity to the exhaust manifold, etc
/ Case Jx95
/ Case Jx95
Yes it happens in the same spot on the bottom close to the hose clamp.
/ Case Jx95 #7
If that is the exhaust manifold right below that clamp, a heat shield should help. I'd check for exhaust leaks in that area as well.
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 PETERBILT 579...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
