sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,618
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
As I recall, my TI 99a, used whatever tape recorder I supplied, there wasn’t a TI one.
Speaking of Commodore, many years ago, got a call from a guy that wanted to connect his to a big CNC machine. They made specialized parts for Boeing. The first problem i ran into was the tape deck used to store the programs, the output was too variable so would overdrive the input and cause distortion. I made a little circuit with a D to A converter to connect between the two devices. Then ran into an issue with the connection from the Commodore to the CNC machine, it was serial, but not exactly standard, i had a breakout box an figured out the pin out. Then ran into an issue with the programs, that wasn't my job to figure out, but i did talk to the Japanese tech a bit and between us, figured out where the owner was going wrong. From what i heard afterward, it worked out well for him.Yeah, my Commodore had cassette tape storage, but I convinced myself to buy a 5.25 floppy drive soon.
What is the consensus on hardwire vs BT for the router connection. And what kind of range are you seeing indoors with normal stud and drywall construction? Is 60-75 ft doable through many walls?
If I use an Ethernet cable to my PC so I can game online in the evening - can I still use BT on another device at the same time? Or is it one or the other? Anybody know, thank you
I'm not sure what you are asking, but.What is the consensus on hardwire vs BT for the router connection. And what kind of range are you seeing indoors with normal stud and drywall construction?
I have an original SL system which has a single ethernet output by default. I connected the SL router to a simple 4-port switch. From there, one connection to my TP Link Deco M9 mesh system which distributes wifi throughout the house and the two PCs which I wanted direct (non-wifi) connection. This works beautifully for me.What is the consensus on hardwire vs BT for the router connection. And what kind of range are you seeing indoors with normal stud and drywall construction?
The Starlink system itself is very easy. The complexity comes in if/when your home networking needs are challenging.I see there is going to be a learning curveI'm looking forward to this upgrade! Thanks for your replies and I'm sure I'll have more Qs when it gets here. Click image to see the joke.
