Need direction on unsticking clutch on John Deere 870
   / Need direction on unsticking clutch on John Deere 870 #11
Chain it to a stout tree by the drawbar, put it in a high gear (engine off) depress the clutch pedal, start the motor (throttled up a bit) and hang on. When it gets to the end of the chain, it will break loose. Done it a few times, always works and why neither of my tractors have clutches. I really dislike dry clutches.
I guess you've never thought of possibility of a tow chain breaking then hitting you? I've heard of putting blanket over chain to lessen chance of this happening BUT your method sounds as if an accident has a very excellent place to happen.
   / Need direction on unsticking clutch on John Deere 870 #12
forgot too add the blanket and always use at least a Grade 80 chain. Non issue here now as none of mine have dry clutches. The dry clutch tractors are long gone. Chaining to the drawbar and low on a tree keeps things down low in case the chain does break. As usual it is always 'at your own risk' and I'll leave it at that.
   / Need direction on unsticking clutch on John Deere 870 #13
You may be able to free it by just driving it briefly with the clutch in. You want to be in a gear that will cause the engine to work hard going up a mild hill or other convenient feature of your property. You may be able to start the tractor in such gear, but if not you can start in a lower gear and upshift while rolling and feathering the throttle. Once in the appropriate gear try to accelerate up the hill at full throttle, clutch in of course. Try a couple or 3 times but not many because long time running with the clutch throw out bearing loaded at operating RPM is a wear gamble. If it does free up fairly promptly good - if not chain to a big healthy tree from the tractor drawbar as described in others posts. You may want to protect the tree bark at the chain point.
   / Need direction on unsticking clutch on John Deere 870 #14
Were you ever successful getting the clutch plates to release ?
   / Need direction on unsticking clutch on John Deere 870 #15
   / Need direction on unsticking clutch on John Deere 870 #16
Yep, I'd push the clutch pedal down and keep it down while I drove it. Hit the accelerator and let off, just vary speed, hit brakes. You may have to tie it to a truck and drag the truck to get the clutch free.
That screw driver trick may work but you need to have the pedal down. The clutch needs to be in release position so screw driver can release it.
Any pictures of exactly where I need to be praying with a screwdriver? Have a JD 870 that was parked on a hill in gear, a few days later went to move and now clutch is stuck.
2011 WESTERN STAR 4900 SB (A50854)
2011 WESTERN STAR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
