Piston of Stihl MS361 Clone Kit Saw
   / Piston of Stihl MS361 Clone Kit Saw #11
I see some once blown up. But I have seen that on other saws that ran great newer or older oem too.
Could be rough bevel in exhaust area etc. Why lot of guys guys the extra mile to smooth out the bevels in the afm cylinders.
Without going OEM on stuff. I used to use meteor but their quality has dropped on some kits.
But to the point I been using Chris's piston kits in a few saws with great results. Feedback from others is what made me give them a try. THE DUKE'S PERFORMANCE COATED PISTON FITS STIHL MS341 MS361 HOLZFFORMA G366 47MM
Great feedback on his p+c kits too. THE DUKE'S NIKASIL PLATED PISTON AND CYLINDER FITS STIHL MS361 KIT 47MM HOLZFFORMA G366
Thank you, I just ordered Dukes set and will update once it's installed and been running for awhile!
   / Piston of Stihl MS361 Clone Kit Saw #13
   / Piston of Stihl MS361 Clone Kit Saw #14
Can you elaborate on how you do your muffler modification on a MS361?
I for one am not opening the inside of muffler by uncrimping to remove all the restriction inside. I just open the outside with a deflector or gill. Some use a pipe.
   / Piston of Stihl MS361 Clone Kit Saw #16
Sorry I‘m not sure I understand this part.
Look at the 3 pics you quoted me in on your first post. Shows it and self explanatory. That one is a gill.
   / Piston of Stihl MS361 Clone Kit Saw #17
Oh the opening on the side of your muffler. I was thinking of tools to do it with.
How much louder is it with the modified muffler?
   / Piston of Stihl MS361 Clone Kit Saw #18
Since the baffle is still inside. Not much louder at all.
These saws are just so choked from factory, like a 290-390 too is bad.
On a 290 I seen 23% gain in faster cuts just by opening the muffler. Those are the worst choked ones. I can go right through their baffle and by pass it on those.
Now doing like this cant go got in areas that require spark screens. If that you need to use a deflector with screen under it.
I considered opening up, gutting & re-welding the crimped seam in the muffler of my MS361 clone, but decided it was better to buy one already modified.
Sure I could have saved $65 but would have easily spent couple of hours messing with the stock muffler....
   / Piston of Stihl MS361 Clone Kit Saw #20
I wonder if he cut and removed the baffle inside or just cheats like me and just add more outer opening. No cost that way.
40 (A52708)
40 (A52708)
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
Chemical Containers Tank (A57148)
Chemical...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
