New grapple won't close all the way.
   / New grapple won't close all the way. #13
I have a 1990'S Kubota B2710 that has served me well since I've owned it (10 yrs±)
Last December my Everything Attachments grapple finally arrived. I didn't need it until Spring, so it's only been attached a few months.
Maybe 5-10 hours on it, and suddenly it won't close but half way. -------------
I don't even know how to diagnose this problem. Help?
Remove these bolts/pins.
The lid should close.
Operate the lid cylinders, see if they both extend all the way.
   / New grapple won't close all the way. #14
^ Right. By disconnecting the cylinders, you can independently check if it’s a cylinder not extending, or if the grapple can open and close without them without binding somewhere
   / New grapple won't close all the way. #15
I wonder - are the seals in one or both of the hydraulic cylinders allowing fluid to go past the piston and effectively stopping the cycle. This may also explain why the upper lid is operating slowly now.
   / New grapple won't close all the way. #16
Symptoms of Improper function of the 3rd function solenoid valves?
   / New grapple won't close all the way. #17
Sure hope he comes back and sees all of the good replies.
Maybe 5-10 hours on it, and suddenly it won't close but half way. Seems to open OK (A little slow maybe), but closing just comes to a stop around the halfway point.
Plenty of fluid in the reservoir (maybe too much?).
OMG! Sometimes the simplest solutions confound me...
Sure enough; one of the hose connections had come loose. Plugged it back in tight, and all works great.
SO relieved! THANK YOU ALL for the great suggestions and help!! You've averted me from going into a high-speed wobble....
Of course; this means that now I have to put the bucket back on, and start loading wood into the garage...
UNUSED LANDHERO LDH-SP12 12 TON PRESS MACHINE (A57193)
UNUSED LANDHERO...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2019 Kubota SVL95-2 (A53317)
2019 Kubota...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
