What is a good brand front door lock with "lever" handles?
   / What is a good brand front door lock with "lever" handles? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
House in Northern Va. temperate climate. I'd been buying Schlage and Baldwin. The "brass" tends to get pitted over the years and the locks fail after a while.
The present "problem" (10 yr or older Baldwin lock) is I can't wiggle the key out of the lock.
So until replaced I'll rely on the deadbolt.
Looking at Lowes prices are around $400+ for replacing it with something of the same make and probably lifespan.
Critical features
NO ELECTRONICS - No "smart lock" etc.
Highly rated lock
Lever action, inside and out
Good finish that won't start pitting after a few years.
   / What is a good brand front door lock with "lever" handles? #2
I use Schlage with the brushed stainless finish. I'm with you on not liking knobs.
   / What is a good brand front door lock with "lever" handles? #3
We have a cat who jumps up and grabs those lever handles and actually opens doors!
   / What is a good brand front door lock with "lever" handles? #4
Here’s one of my daughter’s that I am looking after..
I have to keep all exterior doors locked now or else he lets himself and his sister out.
   / What is a good brand front door lock with "lever" handles? #5
Our one Beagle used to open the door vs using the doggy door. Amazing how pets are like your children and never close the door either..
  • Good Post
Reactions: JJT
   / What is a good brand front door lock with "lever" handles? #6
Put a tiny bit of graphite powder on the key then slip in in the lock and and work the key in and out a few times , it will be slick as butter,
That might work, except the key is stuck inside the lock already. I usually just spray some graphite in as soon as a key seems "sticky".
But this lock had already become "loose" and was a high-potential failure point, like a tire just starting to show tread.
   / What is a good brand front door lock with "lever" handles? #8
Critical features
Highly rated lock
You could replace the cylinder instead of the whole thing. If you remove the cylinder you might be able to work some lube into it.
I'll second (or third) the Schlage recommendation. That's what we put on our house. The locksmith who keyed them for us commented on the quality. They weren't anywhere close to $400 but it was a few years ago.
   / What is a good brand front door lock with "lever" handles? #9
check build.com I ordered 5 keyed alike Schlage FB50ACCCAM716 deadbolt/handle sets for about what Lowes is asking for a single. Current price looks like 92 - 200 apiece depending on finish.
   / What is a good brand front door lock with "lever" handles? #10
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
New/Unused Quick Attach Auger with Three Bits (A54865)
New/Unused Quick...
TANK MANIFOLD (A55745)
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
