Loctite, where to use or avoid
/ Loctite, where to use or avoid #1
marhar
Gold Member
Denton NC
Farm Trac 60
Where have you used loctite on your equipment and you are glad you did? Where have you used it and wished you did not use it? Have you ever used red and realized it was a huge mistake?
I have used blue on the tail wheel of my rotary cutter and on the stabilizer chain on the side that connects to the tractor. I have never used red.
/ Loctite, where to use or avoid #2
I have used purple, blue, and red thread locker. I have also used many grades of the green retaining compound.
/ Loctite, where to use or avoid #3
I use LocTite 545 on NPT hydraulic fittings. It works a lot better than teflon pipe dope.
/ Loctite, where to use or avoid #4
I've never used it on the tractor, but I use the medium strength type a lot at work. I find the red vs blue specs differ per brand. For some brands, red is medium and blue is the one you'll need a heat gun to unscrew afterward. For others, it's vice versa.
/ Loctite, where to use or avoid #6
I used Blue Loktite on all 56 wheel nuts on my M6040. I've used Blue - here/there - on many of my implements. Never had the need for any other type.
OH - I also used Blue on the nuts that hold the FEL onto the tractor.
/ Loctite, where to use or avoid #7
The key too is to use it properly. Clean, prime what you have to etc. Vibratite is a great alternative to Locktite for some applications.
/ Loctite, where to use or avoid #8
I see there are quite a few Chinese sellers on amazon selling 'Loctite'. I'd be very careful buying that stuff. If it don't say Henkel on the bottle or tube, it's fake.
/ Loctite, where to use or avoid #9
I hate ever seeing the stuff on anything other than a hex-head.
Allen wrenches, phillips, torx, flat head, etc etc......all way too easy to mangle. Pick a different fastner or skip the loctite.
BHCS and FHCS's are the WORST because of there small hex key size for a given bolt
/ Loctite, where to use or avoid #10
Soooo...... I checked my LockTite bottle. It says Henkel on it. That's supposedly the "good stuff". Better be - pretty expensive as I remember.
Has anybody ever used red and wished they did not? A mechanic told me I might as well weld a bolt on if I were going to use red; I have never used it.
/ Loctite, where to use or avoid #13
Red on the bolts which hold the loader mounts to the frame. They were backing out once every fifty to one-hundred hours. Not no more.
Hopefully I’ll never need to take the mounts off for any purpose. I sure can‘t think of any reason I would need to. I browsed through the Service Manual before I did it, and couldn’t see anything, which would require their removal. If I had seen something, I would have use blue.
My Dad used to use dark KARO syrup, if he absolutely wanted things to stay forever. Said that it caused ferrous metals to rust together. I never took anything apart that he did it to. So, I can’t say for certain one way or the other. But, nothing he did it to ever came back apart.
One of the old timers told me to park my tractor and implements outside from time to time so they would rust together as you described; I thought he was pulling my leg.
/ Loctite, where to use or avoid #16
You need to heat it up to get red loose. Which assumes you can heat things without damage. But with a little heat it pops loose.
I cut the tip off of a tube of the green penetrating grade with my old Leatherman. It penetrated into the hinge, and it wouldn’t move.
Two hours in a 350 oven, and a run through the dishwasher, and it was fine again.
If the oven hadn’t worked I would have sent it back to Leatherman to see if they would cover it under the warranty.
/ Loctite, where to use or avoid #17
One qualifier in using Loctite red would be whether or not you could safely heat the part if you need to extract the fastener. Another might be your darned if you you do and darned if you don't. IE I've locked small engine sumps with it that were problematic. Because if it ever fails, it isn't needing to come apart ever. There are varying strengths of red available as well.
/ Loctite, where to use or avoid #18
The Amazon sellers (offshore) are a lot less expensive that the real McCoy (Henkel) but I question the chemical makeup of their stuff. All I use is Henkel and it is rather expensive. I regularly use both blue and red versions depending on the application. Last 250 ml bottle of blue I purchased was over 100 bucks at MSC.
/ Loctite, where to use or avoid #19
There is a lot more out there than the 242 that you grab from the hardware store. Gels, pens, tapes, sticks, liquids. One thing I really like is the VC3 as it is both removeable and reusable. It isn't a typical red in strength, but works well for mild vibration issues. Vibra-TITE
/ Loctite, where to use or avoid #20
Regret using Loctite? No. I normally use it because it is either recommended in the assy instructions, service manual, or because the fastener keeps loosening. Yes, it makes it a bit more difficult disassembling parts, especially when studs and bolts break. As other's have said, some heat helps it come apart.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
DMI Tiger-Mate Field Cultivator Hitch (A65640)
DMI Tiger-Mate...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
