Runs nice and dies in 20 min UPDATE UPDATE
   / Runs nice and dies in 20 min UPDATE UPDATE #1
Danica
Ulster County, NY
CNH TC40DA & Ford 1920
Update-hired a young freelance diesel mechanic who spent 5 hours going over everything and even he’s not positive it is 100% solved but the root cause appears to be air leaking into the fuel system. He put a new brass flat sealing washer on bleed screw and tight ended all the other connections (including the line between tank and sediment bowl which had to be accessed by taking off instrument panel in cab). I’m not 100% sure we have found ALL sources of air infiltration but now it can run at 2,000rpm indefinitely. Hopefully it will act ok under load when a cut the fields as soon as weather turns sunny.
The most likely source of air infiltration was prob a combination of 20 year old fuel lines (replaced OEM for an obscene price) and old line clamps. Again I replaced all. I think the coup de grace was addition of copper washer on bleed screw. In other words the very thing you use to get air out of the system was very probably allowing very small amounts of air to enter.
Of course, none of this is readily linked to what clearly seemed to be an angina temp issue. If it warmed up at 1500rpm would take 30 min to start having problems but would take much shorter period if warmed up at 2,500rpm. Now, one could argue that the time diff is really attributable to the amount of air slowly (or more quickly) entering system.
**** cut 4 acres at 2,500rpm running pto art 540 for three hours straight with NO PROBLEM. So, issue must have been air infiltration. It is the only reasonable explanation.
Yes, same topic as before regarding a 1920 that runs 20 min then dies. Based on feedback in previous thread I have:
* Siphoned out old diesel and added 5 gal fresh
* removed and shot 30psi air thru every hose shown on top of fuel filter housing (for the one to tank I just shot in air to potentially dislodge any crud on the internal filter and the other two I completely removed to ensure they were totally clear)
* new fuel solenoid
* replaced fuel filter, bowl, and large o-ring
* checked tank cap (on/off)
* exhaust color perfect
* screamed at it (as effective as previously noted tricks)
* monitored voltage (14.64) at battery
* checked outgoing fuel stream from sediment bowl while it was dying and it was strong
* changed air filter
* cleaned radiator and screen
* changed fuel return lines
* changed the braided fuel lines
When it died just now I quickly unhooked the fuel line to the filter and it was gushing out. So, this suggests it can’t be fuel starvation or I’d have just a trickle coming down from tank. Same on the outgoing post-filtration stream.
If it isn’t a fuel starvation/quality issue could it be an air issue? I’ve ordered a new air filter due next week and the current one is 6 years old and seen 300 hours of work.
I haven’t bled the injectors but the fact it runs 20 min beautifully and then slowly dies doesn’t seem consistent with that.
Presence of a Woods FEL makes access really difficult.
The thing that is so boggling is that in a few hours it will start right up and run beautifully until the repeats itself. This is my last shot if the air filter doesn’t solve it (I doubt it will) I will have to get a diesel mechanic to look at it and in this case do dealers come and pick up a tractor or just try to fix it ‘in situ’ with equipment they would have in a repair truck. I’ve done everything on both my tractors for 20 years so this will be a first…
Thank you in advance. Pics attached just for curiosity sake and may show in “off” position inadvertently.
Finally, if the tank were clogged wouldn’t the engine run on the fuel in the sediment bowl until it dried up and then abruptly die?
Danica
   / Runs nice and dies in 20 min UPDATE UPDATE #2
Are you running with the fuel petcock on the filter in the position shown in the picture?
   / Runs nice and dies in 20 min UPDATE UPDATE #3
If Lou’s question doesn’t solve the problem.
Another off the wall possibility is if you have electric fuel shut off on the fuel pump. Possible the coil is getting hot and then to weak to keep open. Coil cools off and cycle repeats. That would shut off engine similar to turning the key.
No, if the photo shows it off it was just because I had just blown air up fuel line. My mistake!
Oh right, I put in a new solenoid and was sure that would fix it. Gotta edit orig post.
I edited orig post per your observation (thanks)
Right, well I did replace solenoid and tested to see it retract with leads to battery just in case. But your point re temp makes a lot of sense because when the temp gauge hits the midpoint (as viewed in cab) then it starts to die. It is as if there is some thermostat or something I’m unaware of that is temp sensitive. The fact the fuel (or air?) starvation takes up to 15 min until final gasps and then “death” is puzzling.
I can let the gauge hit midpoint over 40 min at 1,000rpm or just 10 min at 2,500rpm (approx) in both cases when it is sufficiently warmed up it dies!
   / Runs nice and dies in 20 min UPDATE UPDATE #8
Danica
Does it spit and sputter or just die like turning the key off?
If just dies would tend to make me think more electrical vs fuel or air but I have been wrong more times than I care to admit. Anyway you can monitor the voltage signal to the fuel shut off coil. Or if takes time to cool before restart check to see if that coil is getting full power when stops before turning the key off.
I would think if air starved it would sputter or smoke but could be 110% wrong.
No clue if that model had some form of temp sensor that shuts engine down if it thinks it is over temp.
Wishing you the best on getting this resolved.
   / Runs nice and dies in 20 min UPDATE UPDATE #9
Could be your lift pump is failing. They are pretty cheap and easy to replace and I feel your pain at getting to the sediment bowl with the loader on, all basically the same in that respect.
   / Runs nice and dies in 20 min UPDATE UPDATE #10
View attachment 761884Yes, same topic as before regarding a 1920 that runs 20 min then dies. Based on feedback in previous thread I have:
* new fuel solenoid
* checked tank cap
Danica
Well you proved it's not a tank strainer clog! Your symptoms all point to a fuel delivery restriction. Have you checked the fuel filter discharge hose.? Do you have continuous full flow at the filter discharge? There could be a blockage in the fuel filter head that limits fuel through the filter.
When the tractor stopped and you pulled the hose to the fuel filter, was the filter fuel bowl full of fuel? when you changed the fuel filter did you bleed the filter? Are you sure the gasket in the filter is installed correctly and that you have the correct filter?
Describe the fuel delivery system? Does the fuel leave the tank, pass through the fuel filter, flow into a lift pump and the pass into the injector pump?
If you have a lift pump, have you checked it by removing the outlet line and cranking the engine (mechanical pump) or just turning the key on (electric pump). If you have this pump, when you test it, it should spew fuel like a cow peein' on a flat rock! If you don't have a lift pump, forget this test.
I would also try bleeding at the injectors. At this point, you have nothing to lose by trying this.
Do these checks in the order i have described and report back. Good Luck.
   / Runs nice and dies in 20 min UPDATE UPDATE #11
All the syptoms point to fuel starvation - which means as annoying as this is, it is still a better type of mechanical problem than something broken.
This sounds too simple, but could it be that the air vent is clogged on the fuel tank? Well, probably not since you do say,
"....When it died just now I quickly unhooked the fuel line to the filter and it was gushing out. So, this suggests it can’t be fuel starvation or I’d have just a trickle coming down from tank."
But it costs nothing to quickly loosen the fuel filler cap when it starts to die. Simple test.
Uh....back to your quote - which fuel line did you unhook? Was it the one from the fuel tank to the filter? Or the one from the the filter to the inlet to the fuel pump?
It doesn't matter, because all I'm going to say is that is a good test but would repeat it and this time unhook the other line just to make sure that there wasn't a bubble of air hiding out of sight and then expanding with heat. THat kind of hidden air bubble could be in either the fuel filter cap or the solenoid & gets warm, expands, and shuts off the flow.
And let it run into a can or jar for a few seconds to make sure that you really have continuous flow and are not just emptying the cup of fuel trapped in the hose by the air bubble.
luck,
rScotty
good luck beats good planning
   / Runs nice and dies in 20 min UPDATE UPDATE #12
I didn't know that the Ford 1920 had a fuel transfer pump (lift pump) so I Googled it and sure enough there it is. So it jumps to the head of the list. Much as I hate to throw parts at a problem there comes a point when I will do a bit of that before calling a diesel mechanic.
Right, the die down process can take 10 to 15 minutes so the fuel solenoid is definitely not just springing back into the closed position or it would die fast. Anyway, someone said the solenoid *could* be malfunctioning slowly and a voltmeter did confirm that as the die down started the voltage to the solenoid seemed to fluctuate and go down. So, I bought a nice new one, convinced this was it but…not.
Thanks for your note, I will read thru again for ideas.
D
Thank you for all the ideas. I will try what you’ve suggested tomorrow if it isn’t raining. Didn’t check the outflow of fuel from sediment bowl. Will do that. Yes there is a fuel pump and from the repair manual it seems pretty ez to remove (that Woods FEL is such a PITA when it come to accessing the engine components I almost feel like this would be easier with it off. Plus it has a Sims cab which makes access to tank a real issue). A blockage in the fuel filter head would be a dream…I can only hope and will check tomorrow if possible. I will also try bleeding at the injectors.
Parenthetically a friend with a cat 0 Kubota poured a 5 gal tank of fuel into his machine and he never kept it capped resulting in him pouring an entire dead wasp nest int the tank!! He was able to resolve it with the air blowback but I think this problem will come back to haunt him. Exact same symptoms as mine ironically).
D
   / Runs nice and dies in 20 min UPDATE UPDATE #15
If voltage to fuel shut off solenoid is fluctuating or dropping what is the source of power for the coil?
Can you mechanically tie the shut off open? Some models have levers that make this simple and some do not.
My reasoning is it to try and isolate is this electrical or fuel system problem.
Yep lift pump replacement looks easy as per repair manual. I haven’t checked cost yet. So far I have about $200 into this. Thank you for your ideas!
   / Runs nice and dies in 20 min UPDATE UPDATE #17
By the looks of the lift pump in the picture, it appears to have a screw in the top. That usually provides access to a screen under that cover. That screen can clog partially or completely. If it is partially clogged ........
Ohhhh, that could definitely be it. That’s #1 on my list tomorrow!!
   / Runs nice and dies in 20 min UPDATE UPDATE #19
Have you taken fuel filter off and blown from fuel tànk to filter? Un do fuel pump and blown from filter to pump? I mean compressor blowing. Does your return look good? Blown tank out by putting a rag around blower and blocking return, to pressure the tank?
   / Runs nice and dies in 20 min UPDATE UPDATE #20
When the machine dies (or starts to) can you tell what the level of fuel is in the fuel bowl? If it is not FULL (no air) then than you have a fuel delivery problem. We have the same fuel filter housing / valve on our TC40D & had a similar issue. Fuel flowed perfectly from the tank if the line was disconnected, because the fuel cap vent was working fine. Reconnect it to the fuel valve / filter housing & 10 to 15 mins machine would die. Had to disconnect all the houses from the filter housing & blow them out with air... it was the vent / return line that was causing our problem...
Just a thought... don't rule out a line blockage.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
(APPROX. 20) 4' X...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
Adams Under Truck Conveyor (A56438)
Adams Under Truck...
