Found Good price on 8 ft RC.. OR IS IT? Should I buy this... or hold out???...
   / Found Good price on 8 ft RC.. OR IS IT? Should I buy this... or hold out???... #1
TexasDigger
Kaufman County, TX
Kioti RX7320
My current 6 foot RC is nowhere near enough for the tractor I'm pulling it with. Money is a little tight, but I found a 8 foot RC for CHEAP.. catch is that the internals to the T-Box (center gearbox) are completely gone - center gear box housing is there to compare a new one to, but nothing appears to be inside of it. Also, the Flex Coupler shafts are missing (CV-type shafts from center gearbox to outer gear boxes). The price is CHEAP - almost "too good to pass up" cheap... For such a good price, the question is, do I take the gamble and buy this thing for basically FREE? Worst case - I can buy the OEM retrofit parts direct from the manufacturer for about $1500.00 and be all in for under $2k.. but if I get lucky, I can get aftermarket and be out for a little over half of that. I've found some aftermarket parts that I THINK will work but it is a gamble until I have the unit in hand to match everything up. I know the gearboxes aren't ALL universal, but as long as I pay attention to the gear ratio and make sure all the center and outer shafts line up, I assume it can be done without too many complications..
8 foot would be WAY more appropriate for my 7 foot wide tractor. I wish it were 10-12 ft, but it would still be an improvement over my current 6 footer... The price for sale seems great at first, but after you add in parts + my time/labor which I don' t have much of to spare these days, the question is whether or not this deal is "too good to pass up", or do I just say F-it, pass on it, and hold out for a 10+-footer in field-ready condition for a little more $$$ at auction?? I'm also wondering since I've got almost 30 acres to mow if 8 foot is even enough to be considering behind a 70hp tractor or if I should hold for 10+ since my tractor should be able to pull a 14-footer all day. Unfortunately, most bat-wings I've seen are either DIY hack jobs, or just aren't in the current budget.
Any advise or experience swapping these gearboxes & ability/compatibility between models + a side of "I saw a _________ sell for $________ at auction" appreciated!
   / Found Good price on 8 ft RC.. OR IS IT? Should I buy this... or hold out???... #2
$1000.00 a foot for the increase in size. Wouldn't be worth it to me.
   / Found Good price on 8 ft RC.. OR IS IT? Should I buy this... or hold out???... #3
I would hold out for a 10' or maybe a 12' batwing, prices at local auctions down here ln the SE have started coming down ,and with the almost certain recession coming prices should get lower.
Agreed. I decided to pass on it and hold out for at least a 10-foot RC. By the time I added up $1k minimum for parts + time/labor/PIA factor it just didn't make sense for such a small upgrade.
   / Found Good price on 8 ft RC.. OR IS IT? Should I buy this... or hold out???... #5
If your shopping you should look at the Hiniker 5710 six foot flail mower shredder which has
a CV PTO joint and can mow down to 2 inches.
The 5710 Flail Mower has a standard equipment ratchet jack cutting height adjustment
or it can be equipped with a double acting hydraulic cylinder to adjust the cutting height;
It also has a parking stand as standard equipment.
  • HINIKER5710shredderlit.pdf
$18k 6 foot wide mower... not what I'm looking for. I will be needing either a sicle/disc/drum to cut hay with eventually but not yet.
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
2020 John Deere 450M Round Baler (A53485)
2020 John Deere...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
