mike69440
Elite Member
- Joined
 - Jun 2, 2005
- Messages
 - 3,362
- Location
 - Central NH (God's Country)
- Tractor
 - 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Looks like the max28xl rear end is almost identical to my 2415 that broke in almost the exact same spot.. How is this fix holding up for you? I just bought this tractor and did not know it was broken, I'm curious what caused it. You said you just hit a hole?
Mine also has the same axle lock as yours. How did you modify it so it won't act as a metal shaving dispenser?
See photo.
Driving thru the hole slowly the York rake caught a tree root and 3 Pt had this for a weight weight filled with metal bars, about 750 lbs. Still, it should be able to take it.
