Extra switches on dash of 4105
   / Extra switches on dash of 4105 #1
SgtSluggo
Middle TN
John Deere 4105, Ford 1700
I just took delivery of my 4105. As I was getting used to it, I noticed that are two switches on the left side of the dash that aren't labeled in my manual. Any idea what these might do or is there a checklist of things I could check to see if they affect? Thanks in advance.
   / Extra switches on dash of 4105 #2
Those are not the style JD uses, so they where added by a previous owner. You have to see where the wiring goes to determine what they are for.
   / Extra switches on dash of 4105 #3
In my case, I don't have enough and had to buy one extra from my dealer to the tune of 75 clams but the spot where it goes is already there with a blanking plug so size was important and I wanted them to all match anyway. I thought 75 clams was a bit steep, oh well.
Needed one for my amber LED roof beacon as required now by Michigan law on tractors that are operated on public roadways.
   / Extra switches on dash of 4105 #4
I've just had a look at my 4105 Owner manual (2013 model) and I believe that the vertical switch is for the optional cruise control. (I don't have that option)
Of the two horizontal switches, the upper one is a spare location and the lower one is for your turn-signals... mine is a 'push in' turn-signal whereas yours looks to be a 'slide-over' type.
Here are my switches. (Well, actually one switch 🙂 ):
Thanks!
I don't think I am supposed to have cruise control either. This is just an on/off switch as far as I can tell. I wonder if the previous owner used the additioanl locations to add custom switches. I'm planning on seeing if I can look behind the dash and see if I can tell where they are connected (if at all).
   / Extra switches on dash of 4105 #6
The previous owner may have rigged up extra lighting and utilised those positions.
I have an LED lightbar that I mounted underneath the top of the ROPS, however there is a male/female bullet "socket", just above the PTO, that is hardwired to the light-switch and will activate when switched to the extreme 'right' position (4th position).
Good luck and have fun Mate. Please let us know how it all works out.
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
JOHN DEERE TRACTOR (A57192)
JOHN DEERE TRACTOR...
Dump Truck Body with Tarp System (A55852)
Dump Truck Body...
Metal 5-Point Star (A55853)
Metal 5-Point Star...
