Kubota Cab 3430 / A/C /pressures for A/C
   / Kubota Cab 3430 / A/C /pressures for A/C #1
mkt
Member
Greenville sc
John Deere 2955 / Kubota SVL 90-2
Dad has Kubota with cab. A/C runs for a while then stops working. Anyone know the pressure gauges should read when connected? Thanks
   / Kubota Cab 3430 / A/C /pressures for A/C #2
Just add refrigerant per instructions on can.
   / Kubota Cab 3430 / A/C /pressures for A/C #3
I guessed your tractor AC uses 134A refrigerant. As you can determine from chart below ambient temperature affects correct charge pressures. Be sure radiator, condenser & cab filter are free of foreign material that will block good air flow. I also recommend installing manual heater hose coolant cut-off valve if one isn't already installed.
   / Kubota Cab 3430 / A/C /pressures for A/C #4
   / Kubota Cab 3430 / A/C /pressures for A/C #5
Over filling AC system with 134A is more detrimental(lowers cold air output) more than on older type systems using R12
   / Kubota Cab 3430 / A/C /pressures for A/C #6
You can also ruin a compressor.
   / Kubota Cab 3430 / A/C /pressures for A/C #7
As well as destroy the system from over pressure. The pertinent shop manual will state the correct charge applicable to the system and... your local dealer will know, try asking them.
Winging it can and will destroy the system.
   / Kubota Cab 3430 / A/C /pressures for A/C #8
I've also heard a bad metering device will cause poor cooling.
   / Kubota Cab 3430 / A/C /pressures for A/C #9
Monitoring operating pressures should determine if expansion valve is faulty
   / Kubota Cab 3430 / A/C /pressures for A/C #10
Monitoring operating pressures should determine if expansion valve is faulty.
Well yea but in TBN tradition ,no need for details,just wag at it and go on to next thread.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
TTS5-10680 Rubber Tire Asphalt Roller (A49461)
TTS5-10680 Rubber...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
