4400 HST transmission flush
/ 4400 HST transmission flush #1
mowingmario
John Deere 4400 HST
HI, I'm new to the forum.
The screen filter at the bottom of the transmission on my 4400 keeps getting clogged up bad enough that nothing works. I clean it and it happens again. I already wasted about 15 gallons of Low vis Hygard. Is there a way to flush it or only a dealer can do it. It looks like the bottom of the transmission is dirty, but I do not see an easy way to take the bottom apart.
Any help would be appreciated.
Thanks
/ 4400 HST transmission flush #2
Wow. What is the material that’s plugging the filter? Continue to drain/clean until it clears up. But, maybe you can reuse most of the fluid if you can strain it?
/ 4400 HST transmission flush #3
Thanks
I think it would be important to find out why the screen is constantly being plugged. Can you show us some pictures?
Typically a fill and drain a couple of times with filter changes is enough to clean out the system.
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
KMC 13 SHANK CHISEL PLOW (A63291)
KMC 13 SHANK...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
