John Deere 870 weird sound
/ John Deere 870 weird sound #1
Freedom.acres
1992 John Deere 870
I recently bought a 1992 John Deere 870 it has 1300 hours on it after owning for 3 days or so and putting probably 8 hours on it i started hearing a whoooo sound accompanied by the rpm’s jumping up. It appears to be happening in all ranges and in all gears it usually happens when accelerating or putting load on the engine. Any ideas as to what it could be or things I could check. Thanks
I will check that for sure I’m seriously hoping for something simple as this was a large investment and am hoping to get many years of service out of this tractor
Sounds like one of the air intake hoses is loose.
When you say one of the air intake hoses do mean the hose coming from air intake filter? If so that hose seams tight on both ends. Any other thoughts?
/ John Deere 870 weird sound #5
I agree probably clutch slipping, as it is likely to do that under load causing the rpm rise. Not sure about the described sound. Removal or leaking of entire air inlet system is unlikely to change rpm much since this is a diesel engine, unless the filters are horribly clogged. I would think it'd be smoking alot if inlet was clogged. 870 has a 2 stage clutch - first half of pedal push disengages engine clutch, second half disengages pto. Check the clutch free play, and if that is up to spec, there is a little window on the side of the clutch housing with a screen you can remove and look at the thickness of the clutch disc. If you are lucky it'll be an adjustment. If not, clutch replacement requires splitting the tractor. I'd check over the whole unit to make sure all bolts on engine to clutch and transmission are tight to be sure something is not loose and throttle linkage not changing length under load. It is low hours for a clutch to go bad but not everybody is good at using clutches properly.
/ John Deere 870 weird sound #6
Here is a link to people discussing the 870 clutch adjustments. It describes how to access the view port.
New developments it appears that the sound which I can best describe as a whine or hum almost like a tired bearing would make. I believe it is coming from the distribution box located above transmission at base of steering column. Is there a bearing or anything in there that would make a sound like that. Also not sure why it would increase tractor rpm’s. Thanks for all the support here
The tractor makes the sound in neutral and continues making sound even if I depress clutch to the floor
Here is a video link to YouTube of the sound as I view through port in side of transmission. The tractor is in neutral at idle to start you can hear it faintly and it gets louder as I increase rpm.
/ John Deere 870 weird sound #10
Have you measured the free play in the clutch pedal and measured or observed the thickness of the clutch plates? Why chase the sound when you can look at the working clutch parts from the side and determine if they are worn out. If sound changes when you depress the clutch it is likely something in there like the pilot bushing or bearing or whatever the 870 uses. I'd be interested in seeing an illuminated photo of what is in there with the engine stopped.
Free play is the distance the clutch pedal moves down before it feels like it is doing anything - it should be around 1/2 to 5/8". The clutch linings should not be paper thin - more like 1/4" or so.
/ John Deere 870 weird sound #11
If the rpm rises under heavy load, the clutch is probably slipping. If there is a noise in there, it may be that the tractor was run or is running with the clutch out of adjustment, that is, no free play, which tends to make the throwout bearing run constantly, which it should not, and wears out the throw out bearing. So noise is likely the throwout bearing. Just an additional thought.
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2010 Brenner...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
2007 CHEVOLET MALIBU CAR (A66091)
2007 CHEVOLET...
2017 CHEVROLET 5500XD S/A BOX TRUCK (A59914)
2017 CHEVROLET...
225/70R19.5 Tires - Set of 2 (A68134)
225/70R19.5 Tires...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
