Why so Much Work on a 2400-Hour Machine?
/ Why so Much Work on a 2400-Hour Machine? #1
Suburban Plowboy
FL
Kubota L3710
Hope it's okay to put a backhoe question here.
I saw an interesting backhoe on the web. At 29.5K, the price is right, since I would probably be putting under 200 hours a year on it. I don't need a new machine.
Anyway, generally, ads for these things are pretty lame. "Hours unknown." No information about leaks or wear. "Runs!"
I found one with a very detailed ad. It supposedly has 2400 hours on it. Nonetheless, the ad lists a ton of work:
When it came in it had some leaks and a bit of a miss due to not being used alot over the last few years. We started by cleaning the fuel system entirely and replaced the injectors all 4 are brand new after doing so it still had a slight miss so we then replaced the injection pump .In the mean time we went ahead and replaced 3 out of 4 tires , replaced the suspension seat ( had a rip in it ) , repacked most every cylinder , serviced the unit , greased , pressure washed , replaced the decals , and did an upper end service. The upper end serviced consists of a fresh head gasket , having the machine shop plain the head , re-work/ replace the valves , valve seats , copper orings ect.and re-torqued head to oem specs.
Here is what I am wondering about: how can all that work be needed just because a machine sat around? Most of the hydraulic cylinders had leaks. And why would a machine with 2700 hours need to have the head planed and the valves replaced?
I know 2400 hours mean it's not new, but I know a lot of earth moving machines go much longer than that. I always assume any tractor under 4K should be in reasonably good shape.
/ Why so Much Work on a 2400-Hour Machine? #2
I try to avoid buying a machine with that’s had a ton of work. I’d rather have a machine or vehicle that’s worked for 20 years and with a few minor problems vs one that’s had 20k in work. One is a good machine and the other is a piece of junk.
It clearly blew a gasket at some time, but I don't know why that would necessarily screw up the valves. Maybe they ran it with a bad gasket and coolant got in there?
/ Why so Much Work on a 2400-Hour Machine? #4
How old is it? I agree with the poster above you. When something starts needing that much work you have to figure that something else will go wrong.
I'm the master at buying machines of various types which turn into money holes.
Ad says it's a 2005.
/ Why so Much Work on a 2400-Hour Machine? #7
Most of my stuff is old enough it has had some work, so that doesn't scare me much. Sounds like this one might have got hot with all the top end work, I would probably avoid it. The tires, seat, and seals sound pretty normal for the year and hours though.
best,
ed
Perhaps I will learn those things if they decide to respond to my inquiry.
/ Why so Much Work on a 2400-Hour Machine? #10
Generally, if someone is proud of what they are selling, they will expand on the fact that it has had regular maintenance and provide service records, even if they did all the work themselves.
Vague seller descriptions means they are hiding something.
I'd run away from this one!
They're running away from ME!
I'm checking out an equipment auction next week. Why buy from people who buy from auctions when I can cut out the middleman?
/ Why so Much Work on a 2400-Hour Machine? #14
Look at the exhaust. If it looks like rain water could get down the exhaust, that may be the reason for rebuilding the whole top end. I'd pull a leak down and compression test, and if good, not be too concerned about it. If you were in my area, cylinder that are tight in the summer weep in the winter until warmed up (if they ever do get warmed up, that is), but you're down in Florida, so I cannot say why the cylinders needed to be repacked. I would thing hoses would rot out long before cylinder would leak unless the hydro oil was old and contaminated with rust.
/ Why so Much Work on a 2400-Hour Machine? #15
With something in that shape you had
better just purchase a brand new macine
as the repairs just might get the cost up!
So just save your self the hassle and get
a new machine that you can use right away
instead of having a back to pay for all the
repairs and parts plus all the time it takes
to get something like up and running
willy
willy
It's running now. They claim they rebuilt the top end, packed most of the cylinders, and replaced three tires
I'm not spending $120,000 on a new machine. Only crazy people, big companies, and billionaires buy new backhoes. I could rebuild an old machine from the ground up for a fraction of that.
Also, new machines have expensive eco-crap on them, and it breaks down a lot.
/ Why so Much Work on a 2400-Hour Machine? #17
I work on my machines when they need it but realize that every time I do I'm probably doing something that will require more work later. It's a downward spiral IMHO.
/ Why so Much Work on a 2400-Hour Machine? #18
I understand all machines break but when something has already had a whole pile of work it’s a trend that’s probably going to continue.
/ Why so Much Work on a 2400-Hour Machine? #19
Was it by chance a flood machine and water killed the top end and injection system ? Sounds like it had some rust or something in the top end to require that kind of work.
I don't know anything about its history because the dealer apparently has a policy of not responding to inquiries. I think you're supposed to drive to the dealership and take hostages in order to get a question answered.
Today I went to an auction lot. They had a lot of equipment. Trucks, backhoes, tractors...you name it. The backhoes looked pretty bad. Wet hoses. Bald tires. The auction people don't list the hours on the machines, and you can't turn them on to get the digital dashboards to tell you.
There was no way to tell how much play the booms and sticks had in them because the buckets were on the ground.
My impression is that either they sell these things dirt cheap, or only morons buy them. Maybe they turn the keys on auction day. I didn't ask.
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2017 Ford F-450 Liftmoore 5000W 2 Ton Crane Service Truck (A61573)
2017 Ford F-450...
UNUSED SDLANCH PULL TYPE WOOD CHIPPER (A64281)
UNUSED SDLANCH...
(INOP) 2016 POLARIS RANGER 570 EFI RTV (A64280)
(INOP) 2016...
