JD 990 power beyond no longer available
   / JD 990 power beyond no longer available #11
I tried but it wouldn’t let me.
Thanks
   / JD 990 power beyond no longer available #12
Get a few more posts and you will be able to use more of the TBN features.
   / JD 990 power beyond no longer available #14
We'd like to hear more about y our JD 990. What you use it for and what you are going to add to need power beyond. Maybe a back hoe? or a grapple to the FEL?
Use my added 3rd SCV to activate the hyd. top arm, and then switch connections to run a Thumb on the forks.
JD parts shows a kit (probably the one no longer available) with part numbers. You can check it out and wander the other pages for some more info and part #'s
Copy of one page to see what I'm talking about.
   / JD 990 power beyond no longer available #15
Here is a listing of individual parts for power beyond. Hope it helps.
  • SideBySide (1).pdf
   / JD 990 power beyond no longer available #16
I’m added one set of rear remotes to operate a cylinder to raise and lower a blueberry harvester, as well as an 11’ John Deere rwa disc.
I ended up having to install a 1/4” pipe plug into a hole under one of the main plugs to redirect the fluid flow to the outlet port.
It’s works great for what I need.
TUGGER TRAILER (A55745)
TUGGER TRAILER...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
30007 (A53424)
30007 (A53424)
2015 Ford F-250 Auto Crane EHC32 3,200lb. 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
2013 HERCULES ALUMINUM KILL TRAILER (A55745)
2013 HERCULES...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
