Change shifter boots on 1970 820 3 cyl
   / Change shifter boots on 1970 820 3 cyl #1
jww1960
john deere 820
Trying to change the shifter boots, I am holding the shifter shaft with a wrench so the knobs on both just spin and spin but not coming off..what's the remedy? This is the german made 1970 3 cyl tractor. Thx
   / Change shifter boots on 1970 820 3 cyl #2
If gearshift lever knobs won't come off of lever your next option is remove retaining ring(item 7) & pull lever out of shift cover then install boot.
   / Change shifter boots on 1970 820 3 cyl #3
Try warming the knobs up with a heat gun.
   / Change shifter boots on 1970 820 3 cyl #4
Been my experience that most are a push on, friction fit. Try pulling harder and twisting at the same time.
   / Change shifter boots on 1970 820 3 cyl #5
IIRC the JD ones are screwed on. Check if new ones are available
   / Change shifter boots on 1970 820 3 cyl #7
If they are, most likely there will be a jam nut under it.
No jam nut listed for shifter in JD 820 utility tractor parts catalog.
   / Change shifter boots on 1970 820 3 cyl #8
So, there is no depiction of the shift pattern like my Kubota's have on them then? Mine screw on and a thin jam nut secures them in the correct orientation.
   / Change shifter boots on 1970 820 3 cyl #9
That's odd your M9000 gearshift knob has a thin locknut under the knob as no locknut is listed in M9000 parts catalog under either gearshift knob.
   / Change shifter boots on 1970 820 3 cyl #10
Both of them came that way, if in the parts breakdown or not is irrevelant.
