Near-rollover Cuttin Hay
   / Near-rollover Cuttin Hay #11
I've found cougar tracts within 100yds of the house in that direction. We always have deer and other wildlife around. I suppose that's why. I won't even go out of the house at night without a sidearm.
I even had a few of the neighbor's cattle show up at the bird feeders and corn. :D
Hell, I go out armed because rabies exists. 😂
   / Near-rollover Cuttin Hay #12
I deal with Coyotes and methheads. If it aint locked, it's stolen.
   / Near-rollover Cuttin Hay #13
He said it didn't go all the way to the bottom of the ditch at once, he stopped it first, but though he could get out so he went a little further and then it slid all the way down
He was close to tipping it but not that close. The weight of the mower off to that side helped tip I that way but once it hits the ground you would loose alot of momentum in the tip.
   / Near-rollover Cuttin Hay #14
First mistake he made was “cutting hay at night”. Although its a common practice to cut hay at night, it shouldn’t be done in unfamiliar or treacherous areas at night. That guy is lucky.
Nice recovery job! You’re a good neighbor.
I’ve been stuck one time where I couldn’t get out. Property owner has a JD310 backhoe and it pulled me out in 3 minutes with the dipper stick and a chain.
This reminds me of one of the basic rules in wildland firefighting. NEVER fight a fire in territory you have not seen in the daylight.
   / Near-rollover Cuttin Hay #15
My neighbor was cutting hay at night, on his first round he came up to the fence line and didn't see it until he was in it and started turning and slid into the ditch, was lucky it slid to the bottom and didn't rollover. The Johnson grass was so tall it was higher than the fence. If he would have done this during the day he could have seen other reference points, such as the ROAD on the other side of the ditch, but at night couldn't see far. We've had highs up around 100 so he was trying to stay cool hence the late night....
He is fine no injury. Tractor wouldn't start at that angle. I dug out underneath one side and filled the steep drop-off up with dirt to make a ramp up and out of the ditch, my neighbor pulled it out with his 4020.
Also, I've always been told to open up a field with the cutter sticking out into the field, then turn around and drive where you cut and get next to fences etc, which makes sense to me. He was going around the opposite way of what I was taught.
Soon as I read "cutting hay at night" I thought "oh boy".
   / Near-rollover Cuttin Hay #16
Except for very high end newer equipment (e.g. combines, road graders, etc), the factory lighting on most tractors is nowhere near adequate to safely work at night. It's better not to work at night, but if I absolutely had to work at night with that tractor I would install forward- side- and rear-facing work lights in addition to the OEM lights. A machine used at night should be completely surrounded by a pool of light. Glad nobody got hurt!
   / Near-rollover Cuttin Hay #17
I suppose with the advent of so much solar, some farmers could put in some stadium lights on their fields and power them with the sun. Probably can even tie it in to Alexa...'Alexa, turn on the back forty'. Maybe just a solar LED on each fence post.
All kidding aside, there are times when weather and life conspire to push real farmers into making poor choices. These situations require extra care and the assistance of others. I've seen more than one farm using a truck to help light a field as they attempt to get harvest in. Fortune may favor the bold, but survival favors the wise.
2005 Isuzu NQR 4 door box truck with folding gate (A56435)
2005 Isuzu NQR 4...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
FORKS (A52709)
FORKS (A52709)
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
