replacement light sockets Sc2400
/ replacement light sockets Sc2400 #1
skoullar
Carlisle, Iowa
Hart-Parr, Oliver, White, and Cub Cadet
I'm trying to find replacement light sockets for the lower front "work lights". The plastic is crumbling...
I thought I had found some the would work, but the socket depth puts the bulb to deep into the lens
housing and hits the lens. I'd rather not silicone them in, with my luck one will burn out in a week
and I'll have to cut it out of the housing... Anyone already fixed this problem?
/ replacement light sockets Sc2400 #2
is this the socket your looking for
Yep, that's it, #CY-11A7880-53070 Also, where would I find a wiring schematic for my Sc2400?
/ replacement light sockets Sc2400 #4
actually any yanmar dealer can order the sockets for you part number is 1A7880-53310
I tried, they tell me it's unavailable.....
Correction, the part number you gave me was for the whole light assembly glass metal and the socket, and they're like $40 a piece and $80 to fix two lights well my Scots ancestry makes me a little tighter I'll try to make something I guess. I'm also still in the search for an sc2400 wiring schematic so if anybody's got a lead on one, I'd like a copy.
/ replacement light sockets Sc2400 #7
nope that is the correct number
/ replacement light sockets Sc2400 #8
check attachment below
  • SC2400 electric trouble shooting.pdf
Now the $64,000 question, where are these grounds? I really don't want to cut the harness apart to find this ground. And I could "southern engineer" a new ground, but it would bother me.......
View attachment 756192Now the $64,000 question, where are these grounds? I really don't want to cut the harness apart to find this ground. And I could "southern engineer" a new ground, but it would bother me.......
Never mind.....If it was a snake, would have been bit in a very tender place.....
John Deere Pallet Forks (A66285)
John Deere Pallet...
Cub Cadet Pro Z 972 (A64127)
Cub Cadet Pro Z...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
