Painting YM-146 Clearcoat or no clearcoat any advice
   / Painting YM-146 Clearcoat or no clearcoat any advice
Thank you again great advice
   / Painting YM-146 Clearcoat or no clearcoat any advice #12
I am painting my YM-146 what do you think should I make the last coat a clear coat for protection and shine?
The clear coat on a car new car I bought, bubbled up, came off in spots, and looked awful. This was a while back, I hope clear coat has been improved since then.
   / Painting YM-146 Clearcoat or no clearcoat any advice #13
West Marine or Defender might have some roll/tip topside paints you can check out. Those face similar chemical exposures as tractors with salt water tossed in. Best results will always be spray, but for the same safety concerns, many diy boaters will opt for roll tip paint.
   / Painting YM-146 Clearcoat or no clearcoat any advice #14
There have been cases of clear coat failure due to improper application. Clear coat is supposed to be applied shortly after the color coat so it fully bonds with it. When done correctly it is rock hard and almost indestructible. If the intent is to clear coat an existing, fully cured finish, there may be products that claim to be OK for this, but I would be very concerned about the condition of the base coat.
The stickers are on looks great.
I also installed a rear LED work-light on the fender. Yanmar looks like they made the fender to add a light since they have an extra hole with a grommet through the fender and under the fender for the wire. I wired it to my head lights which are also custom LED with a plasma cut grill.
   / Painting YM-146 Clearcoat or no clearcoat any advice #17
Yes, there is a rear work light.
   / Painting YM-146 Clearcoat or no clearcoat any advice #18
Nice restore job. It would be great to take to some of the Old Day tractor shows. It would wins prizes.
   / Painting YM-146 Clearcoat or no clearcoat any advice #19
Lots of misconceptions about paint.
If you are using spray cans, or other low end products, i.e. industrial enamels, whether you clear it or not, it's still cheap paint. It's still a soluble finish, which means it can be softened with solvent. It can be fine for farm implements, and misc. items, but it's not ideal, if you want something that will last.
a urethane automotive finish isn't soluble, and is much harder when it reaches full cure. But, a higher skill level is needed to use them properly, and, achieve a good finish. They are also much more costly.
To achieve the highest level of durability, each layer, including the primer, or sealer, needs to have isocyanate hardener in it. And, they must be applied as per manufacture instructions. Usually, that would be a "wet on wet' application. Which means a limited amount of time between the application of each layer. This allows the layers to link together, on a molecular level. That kind of finish is better able to resist chipping.
As far as isocyanate health issues go, there are hundreds of cancer causing chemicals in paint. The required level of protection, is exactly the SAME, regardless of whether you are using a product with isocyantes in it, or not. You don't know which chemical is going to get you, so there is no short cut here.
If you don't have experience using automotive paints, you probably also don't have the required grade of compressed air either. And, the cost to have clean dry air, along with the appropriate level of personal protective equipment, make it a much better idea to hire the paint work out.
If you are still determined to do the work yourself, I would suggest you start out with a lower end, single stage urethane automotive finish. That can give you a solid finish, and shinny paint job, without getting overly complicated, and spending a mountain of cash. See your local body shop suppliers to find out what your options are there.
Make sure you get the product data sheets, and read them carefully. Spend some time making up some test panels, to get used to the product, before you commit to doing something that matters.
And, most importantly, if you are painting something and it's not coming out, STOP PAINTING, until you figure out the problem. 99% of the time, beginners just keep spraying, and keep screwing up, making more and more work to redo it all.
All modern automotive paints are made to be applied how you want them to look. You don't paint them expecting it to "flow out". If it's going on like crap, you're going to end up with crap.
If you have your equipment, and your paint set up properly for the temperature you are working at, you should be able to apply medium to wet coats, and they should look flat right away. Ideally, they will start to tack up within a few minutes after you finish applying a coat. If it doesn't tack up after 10 minutes, what you're using is too slow for your conditions. You need a faster hardener, or reducer or both.
Conversly, if it's not going on smooth, you need to apply it wetter, or use slower chemicals.
Good luck.
   / Painting YM-146 Clearcoat or no clearcoat any advice #20
GT14, that looks fantastic!
Or just a nice electronic air sprayer on the cheap, still better than foam brushes, roll on or whatever.
I hope that HF sprayer is faster than the similar Wagner unit I used many years ago. A whole afternoon to spray a kitchen. Per coat. Never again!
And a general paint question: Is Rustoleum's topcoat, over Rustoleum red primer, suitable where diesel could get spilled on it?
John Deere 1025R (A53317)
John Deere 1025R...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
1427 (A57192)
1427 (A57192)
INTERNATIONAL TRUCK (A52707)
INTERNATIONAL...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
