Yanmar 1303 Tiller
/ Yanmar 1303 Tiller #1
Menagerie-Manor
Gold Member
Brookings Oregon
Yanmar YM2310D John Deere LX172 Woodland Mills HM126
Just came across this Tiller that's only a few hours away for a decent price, any thoughts.
/ Yanmar 1303 Tiller #2
Hey where's YanmarFever? That's where his shop was, he likely sold it to that guy. He would know best of all.
In my limited experience Yanmar tillers are indestructible, it should be good.
If it doesn't include the special top link then you will likely need longer 3-point arms and driveline to get it away from your tires. Some people weld on extensions to get the 3-point pins farther forward. It might be unreasonably expensive after dealing with all this.
1300mm is smaller than your YM2310 would have come with new considering YM2000 came with a 1400mm tiller.
I've seen advice here to replace the offside bearing with a sealed one, since in Japan those tillers run submerged and the bearing is likely rusty by now, 40 years later. And drain/refill the gearcase. There's usually condensation water in there.
Thanks California, the hook up is where I'm concerned and although I can tackle any mods I'd rather not so hopefully someone else can add to it.
1300 is fine for my purposes, I just like the idea of a Yanmar tiller after becoming acquainted with the indestructible nature of their equipment.
/ Yanmar 1303 Tiller #4
Ca, Its not one of ours, we painted and repaired all our tillers to look like new...
/ Yanmar 1303 Tiller #6
Yes it will work, HOWEVER as California mentioned, you will need the special top link bracket that connects the tiller your top link ...
/ Yanmar 1303 Tiller #7
I might have the manual for it. If you do get it, I'll look for it to post here. :)
Seller is telling me he had the top link fabricated so I asked for a pic which I'll post up later.
/ Yanmar 1303 Tiller #9
Here are pictures of the original top link assembly.
This rotates the top of the tiller out away from the tires, as the 3-point is raised.
Comments:
* This link was original on a YM2000. It was needed on my YM240 (YM2000 US version) to clear the 24 inch tires. But running the tiller on the much smaller YM186D shown here that has 16 inch tires, there's more room between the tiller and the tires.
*Also shown is the PTO extender (brass color) given me by the tiller seller. The driveline was originally too short, likely shortened to make room for an overrun clutch. The US Yanmars have an overrun clutch inside the PTO so I needed this extender to make up for not running an external overrun clutch.
*The device clipped on the top of the tiller is my weed cleanout tool. A linoleum knife driven into a piece of conduit. This tool will reach the center of the tiller from either side, and it's easy to use reaching in from behind the tiller.
*I've learned that mowing a week before tilling works better than trying to till tall weeds into the soil, standing weeds get all snarled up in the tines.
View attachment 755142 View attachment 755144
Comments:
That's a big help knowing what it looks like, that's doable for me if what he has is ng.
/ Yanmar 1303 Tiller #11
IF this is so, I wonder if the person selling is a member here on TBN. We've had threads on tillers and the shorter top-link part a few times since 2019. Wonder if there are pixs in those threads of the unit already. ;)
/ Yanmar 1303 Tiller #12
1303 Last one Fredricks had Yrs. ago. On a YM2000. Worked fantastic!! My mother sure like it after having to deal with a walk behind sears. Tilled 6-8" deep if that. In the pic it's set as low as it will go. And the Tractor handled it with ease. That is the shortest the top link gets. Set the Adj. out from there depending on the 3pt. model.
/ Yanmar 1303 Tiller #13
We had to go into a back wharehouse to dig it out. Spalding tractor co. told me I needed to go get it Wouldn't last long. Been quite a few Yrs. but the bearing did come up. In dirt like most all US. gardens the dry wears the bearing. Easy to grease up only takes a Min. or Two.....
There's some very useful pic's there thanks, just waiting on the sell now.
/ Yanmar 1303 Tiller #15
IF you are really interested, fire off another polite message mentioned your really interested. :)
Genie Z60 Articulated Boom Lift (A64047)
Genie Z60...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
72†United box blade (A64047)
72†United box...
