Bush Hogging 8 acres - pricing?
/ Bush Hogging 8 acres - pricing? #1
Skramps
Member
San Antonio, Texas
Massey Ferguson 1526
Hey guys. Sorry if this is the wrong forum to post this. I'm pricing out my first paid job with my tractor and rotary cutter. The customer wants 8 acres of knee/waist high fields mowed. It looks like it has been regularly maintained but not recently so there aren't any debris piles, wooded areas, briars or anything like that. Mostly grasses and some small wooded material. Slightly inclined and rolling but not steep. No large obstacles except a few large trees that have enough clearance around them to cut around. I live in Maine and am not new to landscaping or yard cutting but I've never priced this large of a cutting and not with a tractor.
I have my overhead and profit figured out on paper but I have no idea if I'm too high or low.
I'm assuming an hour an acre?
It's close to 40 miles (one hour) from my house.
Without knowing the market for bush hogging and going off my numbers (theoretical at this point) I would want to charge $750.
To me that seems outrageous for just mowing an 8 acre field but I do all of my own work around my property so I'm not accustomed to paying contractors. I've seen a few people on craigslist advertising $50 an hour but that seems way too low to stay afloat. Especially now.
Does this seem reasonable for anyone else?
/ Bush Hogging 8 acres - pricing? #2
We need your location to provide reasonable responses.
A price in Florida would be unrealistic in New York.
1. Click on your "illuminated" screen name in upper right corner.
2. Click on SETTINGS in drop down box.
3. On left side of screen, click on ACCOUNT DETAILS.
4. Scroll down to LOCATION.
The customer wants 8 acres of knee/waist high fields mowed. Slightly inclined and rolling but not steep.
Massey Ferguson 1526 Dimensions​
Dimensions
Wheelbase:61.4 inches
155 cm
Length:111 inches
281 cm
Width:49.2 inches
124 cm
Height (ROPS):95.5 inches
242 cm
Shiping weight:1873 lbs
849 kg
Ground clearance:11 inches
27 cm
Engine Detail
Iseki
diesel
3-cylinder
liquid-cooled
Displacement:91.4 ci
1.5 L
Bore/Stroke:3.43x3.31 inches
87 x 84 mm
Emissions:Tier IV
Power (gross):24.8 hp
18.5 kW
Rated RPM:2600
Starter:electric
Starter volts:12
PTO (claimed):20.1 hp
15.0 kW
Whether you own a 48" width mower or a 60" mower, with 20 PTO horsepower you will not be mowing thick grass in swathes wider than 48" on average.
With your light tractor I speculate your field mowing speed will be 2-1/2 to 3 mph. You will be operating your tractor at full throttle doing this work.
So, 1-1/4 to 1-1/2 acres per hour cut = 6-1/2 hours "pure" mowing time.
I will speculate your tractor and implement cost at $30/hour, assuming dealer service. So your total tractor cost for 8 acres, AFTER ARRIVAL, will be somewhere around $195, valuing your time at "0". With travel of two hours and 6 gallons/ $25 of fuel for your truck, you will have around 9 hours in the job. I would not work for less than $50/hour as on owner/operator in the south, so a minimum estimate for me, in the South, would be $700.
You should not take on any commercial work without liability insurance.
T-B-N ARCHIVE:
1) So you wanna be a mowing contractor.
2)
/ Bush Hogging 8 acres - pricing? #3
Do yourself a favour and charge an hourly rate and charge for travel time. BTW I see commercial lawn mowing guys charging $100+/hr around here. Be prepared for surprises and breakdowns. Also be prepared for deadbeat customers.
If you call your insurance and get a quote on commercial liability you will think $100/hr is too cheap.
/ Bush Hogging 8 acres - pricing? #4
How many hours with your equipment do you estimate it will take ? You haven't done this before so there's an unknown hazard factor. One shredded tire will cost $750. You can always provide a second cut discount if no hazards found...
I was mowing a field with a bush cutter. I saw quick movement on the ground next to the tractor. I thought a snake. Turned out to be a barbed wire fence. I spent the next two hours cutting it from the shaft of the rotary cutter. :mad:... before finishing the job. luckily it didn't take the shaft seal out. Otherwise, the job would have cost me.
/ Bush Hogging 8 acres - pricing? #5
SKramps - how much do you want to make an hour ? Unskilled labor around here is $25 an hour and pushing for $30 I think you've got to get no less than $45 an hour, and high end $60 an hour, including time to load and unload. Add the cost of the tractor and fuel. Not less than $15 an hour. Charge for the travel at $2.50 a mile. I think the $750 is right in line.
/ Bush Hogging 8 acres - pricing? #6
Cracking up at the charts & graphs.
Don’t know your mower size, but we do custom mowing all day long (hay baling, field mowing and large lawns). I would mow 8 acres of the grass you describe for about $400-$500. It would probably take me 2 + hours and my goal is to get as close to $200/hour as I can get. Though most of the time I end up around $175-$200/hour. I am using either a 130HP tractor & 15’ mower or 200HP tractor & 20’ mower
/ Bush Hogging 8 acres - pricing? #7
After 11,000 posts on T-B-N I find it baffling how few new members specify their location.
I find it difficult, sometimes impossible, to post solid information without knowing where the OP will operate the tractor.
Here are my reasons for wanting OP location.
Everyone on T-B-N has a screen name, as anonymous as they like. Any other profile information is contributed voluntarily, such as age and tractor brand/model. Relative to the massive data heists reported so often, with names, address, Social Security and credit card numbers stolen, this site is nearly anonymous.
Since you sold your tractor maybe take a long break from this forum if you get so bothered with people not putting in their location.
/ Bush Hogging 8 acres - pricing? #8
At the end of each summer, I would brush hog roughly five acres of field with my MF 1540 HST. First cutting in low range most of the time (the wetter areas of the field grow thicker and taller than other sections - about 50/50 though, so it averages out). Takes 3-4 hours. Probably used five gallons of diesel. Really not any other costs due to mowing (going to own the tractor anyway, so don't care about the actual equipment cost recovery).
I would then let it dry for a few weeks and do another cutting, but in mid-range. Main reason for the second cutting is just aesthetics - better mowed look to it.
So....8 acres will probably take you all day, mainly because you're not familiar with the land, and haven't figured out the best mowing pattern yet.
If you're comfortable with $750, then go with that. Don't overthink it too much. Worse case, it ends up being a nightmare, and you never do it again.
Good points. I've become very competent in other areas of my business with pricing and am spot on. This is like I'm a new business owner again. It took a lot of nightmare jobs that were priced horribly for it to get tuned in. I think I'll fair a little better now but you're right.
I appreciate the pricing info. Makes me feel a little more secure that I'm not daft trying to get my rate. I'm coming in with a $50/hr profit price point and a $32/hr overhead rate with a 10%/hour unforeseen amount.
Edit: I'll be using a 60" rotary cutter
We're at about the same for skilled and unskilled labor. Fast food places are hiring at $18. Trades are upwards of $60. I'm figuring my hourly rate based on how I price the other parts of my business but with obviously different inputs. I'm happy that I'm not reaching too far away from what the norm seems to be. Thanks
ALTIITUDE - Tractors lose 3% of engine power output for every 1,000' altitude increase, over 1,500' Sometimes twenty posts will be made advising on tractor horsepower, then we find OP is a 6,500 feet altitude and is considering a low power, naturally aspirated tractor.
WEATHER - ESPECIALLY SNOW - Blowing snow and mowing are the two tasks that require considerable engine power. If we know an OP is in Buffalo, NY rather than Key West, FL snow needs are apparent.
WEATHER - Large swathes of the country have a continental climate, four seasons, with great temperature variations between winters and summers.
Areas near the coast have varying maritime climates.
PRICING - Tractor and implement pricing and dealer service pricing varies a great deal. Lowest prices are usually in the south. Prices along the west coast and in the northeast are usually highest.
Some states exempt agriculture and forestry equipment from state sales taxes. Florida is one example of liberal ag sales tax exemptions.
IMPLEMENTS - Availability of implements brands are regional, not national. ie: CountyLine, Rural King, etc.
SOIL AND GROWING SEASON - Whether game food plots or market crops, soil and length of growing season(s) in important. Soil type influences tire selection.
USED TRACTORS - When the OP posts a location, OP is often referred to good used tractors nearby or provided local tractor listings from Craig's List, eBay, TractorHouse, Machinery Peter or other sites.
Appreciate the information. I'm aware of the need for location when posting which is why I put my location in the body of my post. Never actually noticed the location near the screen name. Information added. Thank you
/ Bush Hogging 8 acres - pricing? #13
What you will find is some guys mow by the acre and some by the hour. I sort of do a blend, but give more weight to the hour price.
If the grass is combined with some woody brush, extra thick, etc. I tend to go by the hour-knowing it’ll be in a lower gear (takes longer) and is harder on equipment.
A disadvantage of the smaller tractors & mowers is they are considerably slower, so what might take you 6 hours, takes me 2. A property owner would compare hourly prices and the bigger tractor & mower are usually going to win the bid and also take home more per hour. Downside for me is more expense to own bigger mowing equipment.
I started out with an 8‘ mower over 20 years ago and knew pretty quickly for anything over 5 acres, the 15’ mower was so much faster
Paid off my 15’ mower in 1.5 years. One of my best money makers.
Understood. My goal is to upgrade to larger equipment in 3-4 years but I needed to get started without putting too much money into a new side of the business. Hopefully I can upgrade sooner.
/ Bush Hogging 8 acres - pricing? #15
I wouldn’t travel 40 miles for a tractor job. That’s two hours plus load/unload time, three-four hours. I’d need a $200 show up fee…and really should be more because that’s basically break even.
ETA beer math
7mpg towing at $5.50/gal is 11.5 gallons, ~$65
Oil change on the truck ever 5k at $150, $2
Driving, my time matters, two hrs at $10, $20
Tractor prep at $10/hr, $10
Loading $5
Insurance $115/month and this is a day of that, $5
That’s $110 and no consumables other than fuel.
/ Bush Hogging 8 acres - pricing? #16
Whatever you charge, I recommend you consider an escape clause for yourself in the agreement so, if you have to quit part way through, you get paid for what you've done. I speak from a bad experience on this kind of thing.
/ Bush Hogging 8 acres - pricing? #17
Have you walked the lot?
Lot's of "junk" is known to take refuge in fallow fields. Old fences, discarded tires, etc.
/ Bush Hogging 8 acres - pricing? #18
I thought I wrote this post as I was reading it.
I just quoted 8 acres 20 miles from the house. It is located in the city and there would be trash to pick up from the vagrants. I included 2 million liability insurance for $1000 per cut every 6 weeks.
/ Bush Hogging 8 acres - pricing? #19
Here on the NH coast, trades (masons, stone wall builders, basic wiring/plumbing) are charging out at $75/hr this year and with no equipment - just hand tools.
I think $75 each way load/unload and fuel expense is reasonable. With tractor $100-110/hour working is about right, and as stuckmotor stated if you get 50% done and hit a land mine of debris, or fencing etc. and need to repair your machine you might consider a buried debris clause for the first time mowing - like an hour or two variance in your estimate.
So an estimate of 6 hours would be $600-750 plus $150 travel, and if there are obstacles, you have an out. Then if this is a repeat mowing - every 6 months like summer and fall you can provide a better rate.
Finally what is their expectation of the finished mowing - do they want a "lawn" look or mowed field"? Meaning do you need to double cut both directions?
/ Bush Hogging 8 acres - pricing? #20
ETA beer math
Loading $5
I’d add $10 more for a 1/2 gallon of iced tea and a “sharing size” pack of Goldbergs Peanut Chews. ;)
20 miles would be a roading tractor/mower for me.
I’ll probably go 30 before loading up the trailer.
To the OP: “city mowing” can be a BIG mess. I usually turn down those jobs. I walked a few before mowing and found piles of discarded concrete, rocks, trash, mattresses, etc.
Better add X$/Hour for clean-up. You could lose your shirt fast if you end up spending gobs of time cleaning up. Also, where’s the trash going? Is customer providing a dumpster?
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
2005 John Deere 7320 (A60462)
2005 John Deere...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Kuhn FC400RG (A60462)
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
