Mahindra 1635 Fuel cutoff?
/ Mahindra 1635 Fuel cutoff? #1
Keblac
Mahindra 1635
Hey everyone! Looking for some help on my Mahindra 1635. I’m doing my 50 hour service on it and when I got to changing the fuel filters I cannot find a cutoff for the line? The book makes no mention of shutting off the fuel. It just says remove filter and replace with new one. I tried looking on google and couldn’t find anything. YouTube had folks changing filters on 1626’s and they said that filter had a spring that would cutoff the fuel flow while changing. The filter on the 1635 looks completely different but I removed the pre filter to change hoping maybe it had that spring cutoff too and it was a river of diesel. I swapped fast as I could and still made a big mess. I’ve looked all along the fuel line and don’t see a cutoff. Would they design it this way? I still need to do the main filter and probably double check the pre since I swapped it so fast but don’t want to do anything until I figure a way to shut off the fuel. Any advice is appreciated! Thanks!
/ Mahindra 1635 Fuel cutoff? #2
My 1538 has no shut off for the fuel. It will also cause a river of diesel. I had to use flat vice grips to squeeze the fuel line. There are also fuel clamps designed for this purpose that are probably a bit easier on the fuel line.
Thanks I was thinking I must be missing something! I’ll look into getting fuel line clamps before I replace the main filter.
/ Mahindra 1635 Fuel cutoff? #4
Running into the same issue, how did your second filter change work out. Also, can't figure out how to disconnect the water sensor at the bottom of the main filter.
/ Mahindra 1635 Fuel cutoff? #5
It looks like it must have a rotating sleeve that unscrews then the connector is pulled off--Similar to the old speedometer connections. I don't own a Mahindra so I could be dead wrong but, I just looked at the sensor. (shown below)
/ Mahindra 1635 Fuel cutoff? #6
Thank you. That looks similar to it, couldnt figure out how to disconnect the connector, I'll have to look again.
