Case Ih 995 spinning cover
/ Case Ih 995 spinning cover #1
jwalsh
Case IH 995, IH 1566, IH986, Ford 6700, David Brown 1212, AC 7030
I have a new to me case ih 995. I was working on my haybine last night and noticed this thing spinning next to the pto and I don’t think it should be. What is this part called and should it be spinning?
Here’s the pic with the part circled. I’m new to using a forum so it didn’t attach the first two times
/ Case Ih 995 spinning cover #3
I'd try that over at redpower, you have dual shaft set up, I run a 95 series but it's only single 540. Don't recall anything like that spinning.
/ Case Ih 995 spinning cover #4
The PTO sealcover next to it has a reses in it to stop that shaft from spinning.
/ Case Ih 995 spinning cover #5
It is a shaft with the idler gear between your topshaft and the bottom one.
The piece is flush with the rear end, should it be sticking out some in order to touch the pto cover or no?
/ Case Ih 995 spinning cover #7
I looked at my single shaft unit, the bottom cover on mine (no shaft) covers that straight line part.
You can see a straight line in the shaft you are talking about, does the cover around the bottom PTO shaft have a groove that would fit in?
John Deere 6410 w/ 620 Loader (A64047)
John Deere 6410 w/...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
4021 (A59228)
4021 (A59228)
2011 FREIGHTLINER M2 112 CNG DAY CAB (A59910)
2011 FREIGHTLINER...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
