Bailing on steep fields
/ Bailing on steep fields #1
Agvg
Elite Member
Norway
Mf135, Ursus C-355, David Brown 995
Just a pic of a field close to my home
/ Bailing on steep fields #6
We do some crazy steep stuff. Other guys don’t have the balz to do it.
At the bottom of this steep hill is a 10’ drop off into a 2 lane road. There’s no flat area to make a headland or turn around.
Below: This hill has you hanging on pretty tight. Feels like the baler could tip and “gator roll” the tractor and me with it.
/ Bailing on steep fields #7
Hay dude
Are those big square balers as top heavy as they look? I have only been up close to one and it sure looked like center of gravity would be way above the axles.
/ Bailing on steep fields #8
/ Bailing on steep fields #9
Hay dude
they’re pretty stable. The Hesston is very basic. It rides on 2 huge balloon tires and it sticks pretty good on hills. Its only about 24,000lbs.
The Krone is much heavier-about 38,000lbs. It has a steering axle in back and a fixed axle on the front. Both axles have brakes. When you run along a hill, the back axle tends to let the back end of the baler angle downhill if it’s unlocked. I think I will start locking the rear axle along hill sides.
/ Bailing on steep fields #10
Round bales could become projectiles quick
Oh yeah. When I help bring in the rounds for my friends in Pyengana, a number of fields are like this.
I typically do the 'fetch and carry' job with my little (compared to theirs) 4105; there's a LOT to be aware of when doing that. First there's the slope and 'angle of attack' of picking up the round, you have to back down the hill to the collection area. BUT you also have to be aware of where the baler is and if it's ejecting a new round... because if that round starts rolling you need to figure out where it's going and calculate/make sure you get out of its way!
Fun stuff.
/ Bailing on steep fields #11
Y
@haydude, I a, just curious, what is the barn like building across the road? It has an unusual set of doors and windows in it.
Having a skilled operator helps, as does have properly set up equipment. Have you ever seen an Aebi tractor in your area?
All the best,
Peter
Yep the Swiss, Italians and Austrians mow some crazy steep slopes!
Although I wonder how much it will change with some very severe AG restrictions coming into play…
Looking from the outside they must have been doing something right to be sustainable and productive often for hundreds of years…
/ Bailing on steep fields #12
Fun stuff.
Did round bales up until last year along with big square bales. Many years ago I developed the skill of dumping round bales on a hillside without them rolling away. Many times there’s nothing you can do but shuttle them to a flat spot after the alarm sounds. VERY time consuming on big hills. Large square baling eliminates this and cuts the time of the baling process in less than 1/2 on hilly ground.
Even on flat ground its much faster. Its “continuous baling” There’s no wrap cycle and no dumping. This has enabled me to take on a lot more property.
/ Bailing on steep fields #13
All the best,
Peter
Its a huge barn built in the late 1800’s. You can‘t see it, but to the left was a railroad that ran on the berm along the left side of the property until a catastrophic flood hit our little town in 1972.
Anyway, the barn was rebuilt in early 1900’s- a steam engine delivering to my town shot sparks into the air and caught the roof on fire. The railroad rebuilt the barn for the owner.
The doors are typical sliding lower doors for the cows to go inside. Theres milking areas on the bottom. In the back there’s a huge bank and ramp up to the upper floor. Still very useable. It holds a massive quantity of loose hay or small squares. I am granted use of it, but it’s not constructed with tall enough openings for larger equipment of big bales. I can keep a few pieces of equipment in it.
It’s on the National Historic Register. Famous artists have done world renowned paintings there and there are amateur artists there at classes frequently, held by the grandson. The farm family, loved in our community, generously donated the entire property to a local Conservancy, where it can be enjoyed and preserved for eternity.
It’s a great privilege for me to be allowed to farm the property and keep it “farm” for years to come. Many old stories, both good and bad, success and failure just like any farm thats been around for centuries.
/ Bailing on steep fields #15
Yesterday I made a trip down south into the Palouse - MAJOR wheat growing. I noticed that some of the fields are very steep. Not something I would take my tractor onto. I go down into this area, at least, once a month. This year I will go down during harvest and see how they handle these steep fields. I would guess it's the big units with dual tires on each corner or the big tracked units.
/ Bailing on steep fields #16
@Hay Dude Great story, thanks!
All the best, Peter
Those tractors are very interesting. I think Europe needs them because land is at a much higher premium than in the US.
There’s more steep land in Europe. USA has more flat space than it knows what to do with.
/ Bailing on steep fields #17
Hillside combines . They level with hydraulics .
/ Bailing on steep fields #19
Kevin - it's got to be something like that - hydraulically leveled hillside combines. Many of the field are so steep - I WOULD NOT take my M6040 vertically up/down that slope. They must have the some answer for the tilling and planting too.
There is a really neat thing about the area down south. Many of the farmers have gone to planting Canola - Rape. Most of these fields are already bright fluorescent yellow. So bright - you can see the color reflecting on the clouds on an overcast day. You know there is an upcoming field of Canola by seeing the color reflecting off the clouds.
/ Bailing on steep fields #20
I'm right in the middle of the Palouse. No really special equipment is used but farms have gotten so big and he equipment massive that the "normal" tractors can handle those hills. They used to farm them with horses!!!!
I was the header puncher/machine tender for my dad one harvest on steep ground. Supposedly the pull combine would level 45 degrees both ways. I ran it off he leveling gear rack once and still wasn't level. We quit farming that little patch of hillside and turned it into was is known as an "eyebrow" down here
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
Spray Daddy 100 Gallon 30 ft Sprayer (A64047)
Spray Daddy 100...
2005 FRAC TANK 500BBL WHEELED (A63569)
2005 FRAC TANK...
2009 KENWORTH T6 SERIES (INOPERABLE) (A63569)
2009 KENWORTH T6...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
