Did I mess up the measurements on my PTO cut?
   / Did I mess up the measurements on my PTO cut? #21
Hmm. I dunno. I read things like this and I am convinced again that the shortest distance is when the two splines are in line with each other.
That's right. When the output shaft from the tractor is straight in line with the input shaft on the implement, the drive shaft would be at its most compressed/ overlapped position. Question~ when your attachment is all the way down, are the shafts in line with one another? Say the wood chipper is sitting on the ground already and can't go any lower anyway? If so, the only way to go is up thus raising the shaft on the implement and at the same time extending the shaft. So you would be right.
Also, when I use any 3 pt implement, I remove my drawbar since I can't pull anything with the implement in the way, and if it's not there, it can't get hit. Not to mention I only have to remove 1 pin for drawbar removal.
I have to lift it some for the splines to be inline and the drawbar will definitely be a problem when the shaft is installed so that will get removed.
   / Did I mess up the measurements on my PTO cut? #23
Good stuff, thanks.
I went to the Manufacturer for their guidance. Wallenstein has this.
Good stuff, thanks.
Those are better directions for sure. The first option is similar to what WoodMaxx uses and the second option is what I pretty much see everywhere else on the interwebs.
On a related matter what is everyone using to lubricate the PTO shaft? I know there are zerks where I am going to use my lithium grease but use that on the shaft as well? Or use something else like a WD-40 gel
   / Did I mess up the measurements on my PTO cut? #27
I use 00 grease on the shaft and keep it covered when nothing is hooked up, to prevent it from getting dirty.
You'll get varying opinions on what to use but in time you will find what works best for you.
I need something which doesn't harden in winter. In Alabama, you probably don't worry much about that. ;)
Only because the chipper was delivered on it.
He was referring to a long running thread. Pallets in fields You will have to stick around a while to understand it. ;)
Or you can go to "Google" and type in "Pallets in Field"... the above thread will be the first half dozen or so links which pop up.
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
Caterpillar 249D Compact Track Loader Skid Steer (A55851)
Caterpillar 249D...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
