Modified muffler
/ Modified muffler #1
Tchamp
Baldwin Georgia
Power trac PT-2422
Received a muffler from Farmall140 (Thank you VERY much Sir)
But the unit would not fit. I had to modify it so i could install it on my 2425, but i think it turned out pretty well. Had to cut muffler off end then shorten the exhaust end about 3 inches, then rotated the muffler down 90 degrees and put a extension pipe on the exhaust tip so it would go out the rear of the machine. I think it turned out very well, and my P.T. Is more quiet than ever before. Seems to run cooler also without that big muffler it had on before.View attachment 754218
/ Modified muffler #2
High security, I couldn't look at pictures
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
AR500 Coyote Target (A65640)
AR500 Coyote...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
