Need 1/2 18V Makita impact, which one?
/ Need 1/2 18V Makita impact, which one? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
/ Need 1/2 18V Makita impact, which one? #2
What is your planned uses Arly? I don't consider 740 inch pounds to be exceptional. You need to fire up your laptop and go to You Tube and 'Torque Test Channel' and watch their very careful tests of various cordless impact guns and then decide. I let their first article tests decide for me what I purchase.
I'm an air person for the most part and I purchased the Astro Pneumatics Thor 1/2" impact on their recommendation and it's a frigging beast. Waited 2 months for it. Was worth the wait too. On 135 pounds of air with 5/8 air line and high flow couplers, it makes in the excess of 1300 foot pounds break away and just shy of 1000 foot pounds tightening. Nice (quiet) wrench too. Gave my noisy IR Thundergun away.
I also have the Bauer 20 volt 1/2" impact and it's no nut buster by a long shot but it does a satisfactory job. I rarely use an impact to tighten a fastener, only to break them. Far as the Thor is concerned, if it won't break a fastener loose, it will twist the nut off so long as the socket don't crack.
So far, I've split Snap On, MAC and SK Wayne impact sockets no problem. Only ones that have not failed are the HF black oxide impact sockets of all things. Not broken one yet and I whale on them with no mercy.
I am looking for a 1/2 drive 18V Makita impact and wonder which among there models has good reviews from users here..
/ Need 1/2 18V Makita impact, which one? #4
Like I said, check out the Torque Test Channel, they real world test all of them and post actual results., IOW, they beat on them hard.
/ Need 1/2 18V Makita impact, which one? #5
Looking for a makita 1/2 impact like the ones seen below. Which one these do you guys like?​
Makita XWT08XVZ 18V LXT Lithium-Ion Brushless Cordless High Torque 1/2" Sq. Drive Utility Impact Wrench
4.8 out of 5 stars 120
$319.00
8 Used & New from $319.00
Brand Makita
Item Dimensions LxWxH 4 x 10.4 x 10.3 inches
Material Alloy Steel
Head Style Fixed Square, Hex
Item Torque 740 Inch Pounds
Surely, 740 inch pounds is a typo? That converts to 61 foot pounds and just seems lame for a $300 tool.
/ Need 1/2 18V Makita impact, which one? #6
Believe that would be 740 foot pounds. I f you scroll down in listing it states foot pounds. I have the 3/4 drive version of that model. Very happy with it. Never failed to loosen nut yet of any size i have tried
/ Need 1/2 18V Makita impact, which one? #7
I just acquired a 40vlt 3/4" drive makita. You gotta watch it or it will pop your wrist. Retailed around the 500ish range. But work supplied it.
730ftlbs breaking force seems like a lighter duty model for an 18vlt brushless 1/2" impact.
I have a Mac 1/2" impact that's rated for 1,100ft/lbs breaking force. 900 tightening. This gun is identical to the Dewalt 20 vlt heavy duty. That retails for around $340ish. Guns going on 5 years old and used daily for tightening and lossening large nuts and bolts.
Coworker has the light duty 1/2" Dewalt gun the retails for around $260. Less if you wait for a sale. Great for changing tires and most of your needs. And has a similar rating as the makita your looking at.
$300 seems a little steep in my book for the makitas with that rating. Especially if it's 700ft/lbs breaking force.
Edit: I checked the specs and looks like it's similar to that rating for my impact. 1100 breaking force, 700 tightening.
I say go for it, and try it.
/ Need 1/2 18V Makita impact, which one? #8
Thanks, that makes more sense!
/ Need 1/2 18V Makita impact, which one? #9
So far on TTC, nothing has exceeded the Thor (air or electric) for nut busting or bolt breaking torque. It's very light too with no heavy Li Ion battery. I usually have it on setting 2 (of 3) because on 3 at 135 psi, it's insane. Astro Pneumatic makes some dandy air tools. It is CFM hungry though so it don't perform with a small compressor and it needs large diameter air line and high flow couplers.
/ Need 1/2 18V Makita impact, which one? #10
My "Go To" cordless tools are the Makita 18 volt XLT series. Compact and Sub Compact impact drivers and drills. I still use 1/2" Air Cat pneumatic for the tough stuff.
/ Need 1/2 18V Makita impact, which one? #11
It is 740 ft/lb forward and 1180 ft/lb reverse
/ Need 1/2 18V Makita impact, which one? #13
I see that all the YouTube mechanics have gone cordless. They may have something there. I do tire of dragging around air hoses...
/ Need 1/2 18V Makita impact, which one? #14
I pretty much did that. Got a 1/4" to 3/4" drive. The only time I break out the air hose is if I need the consistency or booty of the pneumatic gun. And that's mainly for installs where it's mission critical that I reach a certain torque that's questionable hitting with a battery operated gun.
It's also super handy when having to work on something where you don't have access to an air compressor.
And I only have a pancake construction compressor and already have 18v makita's that I like, so that's why I'm looking at there bran.
/ Need 1/2 18V Makita impact, which one? #16
I usually do the final torque with a torque wrench anyhow. I'm sure the wife will let Santa know I'm going cordless on the impact wrench! Thanks for the nudge.
Ya, I believe I have 4 torque wrenches.... I inherited some impact sockets and just what to put them into service when i work on atv's and snow implements. Never onwed a impact wrench, but did use them at work so maybe nows the time to get one?? 😁
Do we need to send your spouse a Christmas needs note? :LOL:
/ Need 1/2 18V Makita impact, which one? #19
FWIW: I use the 18V Makita drill/hammer drill for driving up to 5/8" sockets on 3/8" drive. I use it a fair amount because change the torque setting is so fast. It has more torque than I need for most assembly/disassembly. I use air tools for the 1/2" and 3/4" drive, as my service needs are all at my shop, not out in the field.
All the best,
Peter
/ Need 1/2 18V Makita impact, which one? #20
I am a labor saver. I'd rather a Tool do the work.
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
Blue Diamond 103709 (A53317)
Blue Diamond...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
24in Bucket Mini Excavator Attachment (A59228)
24in Bucket Mini...
