LX178 Shuts Off After 15 minutes
   / LX178 Shuts Off After 15 minutes #1
DeansR
LX178
This previous post by another member explains the problem I am having with my LX178. Does anyone have a suggestion? I have also replaced the carb, fuel pump, fuel lines, filter and cap. Thanks, Rob
My LX178 starts fine, runs for 5, 10 maybe even 50 minutes and then stops as if out of gas. It won't restart unless full choke - then maybe runs intermittently and dies. If it cools down for an hour I can repeat the process over again...
I have a new (last year) dealer installed carb, I've checked the gas cap, blown the fuel lines and even blown a bit of air thru the carb after removing the float bowl. The fuel is new, the fuel filter is new and the tank is clean. Any ideas?
   / LX178 Shuts Off After 15 minutes #2
Sounds like you've taken care of the fuel side of things. Might it be electrical? Intermittent coil connection, plug wires, other connections??
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2013 Dodge Journey SE SUV (A55853)
2013 Dodge Journey...
CUMMINS ONAN SD 2000 GENERATOR (A55745)
CUMMINS ONAN SD...
Utility Trailer (A52377)
Utility Trailer...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
