John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,571
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
Mine is the 35E. They made a few improvements when they came out with the M model. If I remember correctly, something in the clutch or brake linkage was changed, which protected it better and made it more reliable. (I've not had significant problems with mine.)There are 3 of those in town including mine, all behind Kubota L3301 tractors. They seem to be solid winches. I believe that is also what John Mc has, and he is quite knowledgeable about small woodlot production in general, as well as using tractors to cut wood.
I think that you will be glad that you bought it.
All of these manufacturers seem to give HP ratings for their winches. I'm not really convinced that's the limiting factor. The 35M is rated for about 16-45 HP. My tractor is 27 HP at the PTO, so I'm in the bottom half of the recommended power range. I don't think I've ever found myself thinking I needed more HP when winching. I don't think I'd want to go much lighter weight or smaller frame, at least not with this size winch. (And yes, I'll admit: there are times I wish I had a bigger tractor, but then there are also times I could not get into all the places I need to with something bigger.)
