Cub Cadet XT1 stumbling/sputtering
/ Cub Cadet XT1 stumbling/sputtering #1
Gomi_otaku
John Deere 3020, Cub Cadet XT1
Couldn't find anything in a search- my XT1 has started running odd when driving it around or idling. I tried driving it down the street yesterday for a nice smooth run with no bumps to throw off the seat sensor or affect the speed.
When I'm driving it acts like the governor is going up and down- bwa bwa BWAAA bwa bwa. Running down the street I could count 5 seconds then it would start "stumbling" for 2 seconds, then 5 seconds smooth again. I say "smooth" but it sounds lean to me, more of a sharp ignition sound.
Now, I run this thing year round, so gas is constantly being added new, nothing sitting around without additive. I've got about 83 hours on it in 2 years. I pull a small cart a lot, sometimes with a 60# hay bale in it but usually much less load. It runs like this whether it's got the cart on or not.
But- when I start mowing, it doesn't "cycle" like that- runs consistent, just with that more sharp ignition sound. I feel like the ignition sound should be less "harsh"
Probably way too much explanation, but let me have your ideas!
/ Cub Cadet XT1 stumbling/sputtering #2
On these the first thing I check on these is fuel flow out of the tank and look for debris that could plug the outlet. Strange, but I clean a few of these tanks a season. Also the roll over valve on top of the tank doesn't always vent and if a non fuel pump model, they can't always deal with a restrictive fuel filter. The XT 1 could have various engines in it. Smooth under load and hunting w/o many times though will indicate a blockage in the low speed circuit of the carburetor. Spark plug terminal, carb solenoid terminal and battery terminals should be secure. A few things for you to chew on. Welcome to TBN.
/ Cub Cadet XT1 stumbling/sputtering #3
Tom had some great suggestions. You say nothing sitting around without additive. What additive? If you're open to a change there I suggest Sea Foam. You can go by instructions on the can but initially you may wish to use more Sea Foam until your problem clears. If it's blocked carburetor passages this could clear them. Don't worry about too much Sea Foam - you can easily go past a fifty percent mix with no issues.
/ Cub Cadet XT1 stumbling/sputtering #4
Gunked up carb. Remove it, take it apart and clean it. I've been using a heated ultrasonic cleaner with Chem Tool in it for years to clean gunked up carbs.
I suppose if the rollover isn't venting, a quick and dirty test would be to drive with the fuel cap off or loose. All connections look secure, this symptom is so rhythmic it feels like a sensor issue (I work on Volkswagens) and the system feels like it is "hunting" up and down. I read on a Google search (so not sure what site) that misfires (which happen when shutting off with the throttle set too high) can cause the flywheel shear pin to deform without shearing, which I guess could throw off the ignition timing. I may try the Seafoam, I'm so busy lately I don't want to have to tear the carb apart to clean jets.
Well, runs the same with the cap cracked/off. It's the Intellipower model so a fully electric carb, no way to even remove the bowl so I guess I'll start with Seafoam first before I look up some diagrams for tearing it apart.
/ Cub Cadet XT1 stumbling/sputtering #7
Just a suggestion, have you changed the inline fuel filter. On my XT-2 this past spring started sputtering off and on with about 160 hours on it and I thought maybe some fresh gas that did not help so I changed the fuel filter and its running like new again. I also never use any additives in my fuel gas powered equipment. Good luck on finding the problem.
/ Cub Cadet XT1 stumbling/sputtering #8
Some EFI models had issues with the connector snapping in fully at the ECU. My normal on these first is to check the pins in the connector to know that they are secure, clean and snap into place at every connector.
Well, I replaced the fuel filter and spark plug with no change. Started to remove the carb but realized it couldn't be opened to clean the bowl- which involved disconnecting the module, so I know it was plugged back in securely. It's been at the factory service center since last week, waiting to hear. Hoping they total it out and give me full credit toward an XT2 with a real throttle control.
Just to update- the one thing I didn't try was pulling off the air filter and running it. Well, the guys at the shop knew right away that was what the issue was, and replaced the filter without charging me a hefty idiot tax in diagnosis.
Turns out the Intellipower are pretty sensitive to airflow, and even if you take your filter out, brush off the outer foam pre-filter, and the main filter LOOKS ok, it could still be clogged.
I'm back up and running through 20" pasture grass.
/ Cub Cadet XT1 stumbling/sputtering #11
Good to hear. Now you know too what the problem is next time.
Figured I would update, since often when Googling a problem you come across something that matches your symptoms...but then never find the final resolution in the thread!
Well, I'm back! 200 hours on the machine now, and hunting for a solution I found my own thread!. Tried all the previous- running with gas cap cracked, replacing the plug, running with air filter off- and no change. But operation is just the same as last time.
I was told then, always turn the throttle to lowest, key on, and wait for it to do it's prechecks (the display will change from battery voltage to mileage) Then start it and adjust throttle as necessary. Which has been fine until I mowed my yard a few days ago. Figured it was the air filter from all the dust, removed the filter and it runs the same.
/ Cub Cadet XT1 stumbling/sputtering #14
May be time to apply @5030 's solution from two years ago.
/ Cub Cadet XT1 stumbling/sputtering #15
If it feels ignition like, tear off the shielded spark plug terminal assembly and install a new non shielded one. These go flaky on the Powermors.
Nope- this mower gets used year round, never sitting. This happened after I just mowed my whole front and side yards. I figured it was the air filter, but taking it off to test it runs the same. I'm going to try a new fuel filter and air filter just to know they are not the issue.
/ Cub Cadet XT1 stumbling/sputtering #17
Get some mechanic in a bottle and dump that in after you change the fuel filter. It'll clean it up.
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
LOOK! (A63111)
LOOK! (A63111)
