Countyline 3-point post hole digger for New Holland TD24DA
   / Countyline 3-point post hole digger for New Holland TD24DA #11
It really depends on the soil. I have clay, and I have to be very careful or I will screw my tractor to the ground.
Yes, I have clay here too.... the type of clay that they make adobe bricks out of..... it is as hard as concrete when dry. Hence why the tutorial and "take small bites" and "frequently lift the auger" ..... so it doesn't screw into the ground.
The PHD has to be set up correctly in order for it to work correctly.
That hole you made (circled in red) is going the wrong direction.... you need to move the U shaped support mount AWAY from the tractor, more towards the center of the boom.
Follow my previous post to set the boom correctly.
I just custom made the legs for standing the augur that were missing when I brought it.
Also, drilled another hole between the last and second Hole which was the last hole originally.
Will test digging the hole today.
jkk
   / Countyline 3-point post hole digger for New Holland TD24DA #13
Try wetting the spot where you want the hole, the night before with plenty of water and I idle my engine with the PHD. never above an idle. Mine 'hangs' in a tree most of the time anyway.
I Tried to dig again.
The boom lifting was perfect. It was lifting the auger just above ground after drilling the hole between the middle.😉😉😉
But it's still hard to dig the hole. .😩😩😩
It is stuck in the hole continuously.
Probably 3 point hitch lifting capacity is not enough to lift when the auger is stuck.
Time to get rid of it.
Jkk
   / Countyline 3-point post hole digger for New Holland TD24DA #15
Jkk
Did you try just taking "little bites" at a time? At most 6" deep, maybe less, lift it out. Any deeper and it will corkscrew....
   / Countyline 3-point post hole digger for New Holland TD24DA #16
When I use mine I 'Pump' the auger up and down, I have plenty of power to lift it but why bother. There is a learning curve with them. Like I told you to wet the area down where you want to drill for instance.
I even adjusted the drop rate valve to the lowest possible to slow drop the 3 point hitch lower link but still stuck the auger too easily.
It is not worth trying again..😥😥😥
Jkk
This handheld auger purchased from local craigslist for $65 yesterday is much better..😊😊😊
It is lightweight (only 30lb) and easy to handle.
No more 3 point post hole digger.😉😉😉
Jkk
   / Countyline 3-point post hole digger for New Holland TD24DA #19
Man. Ive used those and hated them…..dont know how many times we were thrown around when it encountered a rock.
   / Countyline 3-point post hole digger for New Holland TD24DA #20
He gets to find out the hard way.. I had one too, converted it to an ice cutter for winter fishing. You lock the auger in a rock, it's impossible to let go of the handles fast enough. Hard on the wrists too.
I don't use any of them any more. Bought myself a Shaver post pounder, but then his tractor is too small for one. The Shaver I have will drive railroad ties if need be.
Had the right tool to begin with. Just needed to learn the correct way of using it.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2011 KENWORTH T370 (A58214)
2011 KENWORTH T370...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
