Beware of Catalytic Converter Thefts
   / Beware of Catalytic Converter Thefts #81
No car transmission that I've seen less <7.5" tall. You must have jacked it up.
Not that I recall. I had to drag it back towards the rear of the car to clear the front frame members, then dragged it out from under the car. I didn’t own jackstands or ramps back then. Maybe I dug a trench in the gravel. It’s been a long time. :oops:
   / Beware of Catalytic Converter Thefts #82
Thinking about it, I did it in my dad’s carport. Cement floor.
   / Beware of Catalytic Converter Thefts #83
I put aftermarket cats, which have no expensive stuff in them, on the truck I bought.
I'm thinking of putting a sticker on the fenders saying
"Aftermarket Catalytic Converters.
No rare metals inside - no value"
Unfortunately, many of those cheapie aftermarket cats don't work very well. A mechanic friend said he's had to replace quite a few that DIY'ers put in because less than a year later check engine light again.
Can't afford to do it right, so you get to do it twice.
   / Beware of Catalytic Converter Thefts #84
I can attest to that. I had the Muncie transmission out of my '69 L78 Nova at least a dozen times while I had it. It's at least 10" tall any way you turn it, I just measured the one out of my '70 Nova in the shop.
The Saginaw 3 speeds are virtually the same case, just shorter.
   / Beware of Catalytic Converter Thefts #85
Hmmm. Wonder how I got it out of there? Memory is a horrible thing to lose.
   / Beware of Catalytic Converter Thefts #86
That's the risk I take with aftermarket stuff.
A factory pipe with cats would be more than the truck was worth.
When I nought it there was a used factory pipe in the bed that the guy said was supposed to fit.
It didn't.
Pay your money, take your chances I guess.
   / Beware of Catalytic Converter Thefts #87
I'm sure glad we have no emissions testing around here. Considering how many mufflers and converters wind up in the ditches around here, I suspect not many would pass the 'sniff' test.
   / Beware of Catalytic Converter Thefts #88
No emission testing here either, but cats are kind of necessary if you want it to run right.
Or at least work without a check engine light on all the time.
Without the O2 sensors your mileage could go either way. Gas is what? $5/gal there?
   / Beware of Catalytic Converter Thefts #89
If you only have O2 sensors BEFORE the cat and none after it does not affect anything. Older vehicles often are set up like that.
   / Beware of Catalytic Converter Thefts #90
$5.44 USD yesterday.
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
JLG 1255 Telehandler (A55302)
JLG 1255...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
