TYM T474 electrical mystery
/ TYM T474 electrical mystery #1
Matune
Member
Chewelah
2020 TYM 474
Tractor Gaga’s 430 hours on it.
All of a sudden it doesn’t want to send power to the starter unless you jump up and down on the brake pedal or reach in behind the steering column and wiggle wire harness.
Fuel pump and everything else turns on with the switch…just won’t spin the starter without wiggling the ire harness. (I could not see any wear marks.)
I bypassed the brake switch but that made no difference so retuned the wires to stock configuration.
Any chance one of ya know how to track down a broken wire or possibly a ground that hooks up when I shake things a bit?
Or is there another switch on the brake pedals I’m not seeing?
Or just go get another tractor :). They make new ones all the time!!!
/ TYM T474 electrical mystery #2
Check the seat safety switch. The brakes won't affect the start but the seat switch does, so jumping on the brakes could move the seat enough that would make it work right.
Seat has a safety switch?? I generally start the tractor and warm up the tractor out of gear, brakes on, but I’m not in the seat…
/ TYM T474 electrical mystery #4
I would imagine it has one but I could be wrong. At least almost every tractor has one these days.
Thanks! I will check it out!
/ TYM T474 electrical mystery #6
T474 doesn't have a seat safety switch, ONLY on the brakes and if PTO is activated. Make sure harness isn't routed behind instrument panel in such a way that it is chafing any mechanisms.
Cool. Thanks. Are there any grounds under the dash?
I could not see any but I’m not 60 anymore either!
/ TYM T474 electrical mystery #9
I've never had a reason to take the dash apart yet, so I do not know for sure. But I know some T574 users had the park brake lock mechanism rub the wire harness causing some issues.
Perfect! I wiggled the wire harness behind the parking brake lever and the problem went away!
I’ll take the dash off when I do the 500 hour service and repair it then. Assuming that is the problem…hard to see in there with the dash on….
/ TYM T474 electrical mystery #11
Let us know what you find! Could be a simple chafing of the wire.
2015 JLG 3394RT ROUGH TERRAIN SCISSOR LIFT (A65053)
2015 JLG 3394RT...
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A64553)
2025 HT360W Mini...
Wooden Swing (A64557)
2006 Ford Freestyle SUV (A64557)
2006 Ford...
2016 Isuzu NRR Elgin Broom Badger Sweeper Truck (A64556)
2016 Isuzu NRR...
