Ground Hogs
/ Ground Hogs #3
Live trap right over the hole with some lettuce and cut apple for bait.
This was at my next door neighbor’s house June 19. Less than an hour after he set the trap.
/ Ground Hogs #4
No ground hogs here. But I do have pocket gophers - small version of ground hog. I trap and set the bodies out for the coyotes, hawks and owls.
/ Ground Hogs #5
German Shepherd keeps them away here.
/ Ground Hogs #8
As MossRoad wrote,just check the trap often.
/ Ground Hogs #10
I have some 1 3/4 Victors which work well. Just make sure that the chain is short enough so that he can't get back into his hole.
/ Ground Hogs #13
Have to know how to prepare them, just like squirrel. Both vegetarians so the meat is good but all in the prep. I'd never use a scattergun on a whistle pig, always a .17 or a 22-250.
/ Ground Hogs #14
I use quarter to half a cantalope. Never fails. Can possibly get rid of them by putting ammonia in the holes. Worked in NJ. They leave for a while and come back here in Va. In NJ, I'd put a hav a hart trap on a path that they used, without any bait. Caught all sorts of animals including groundhogs in it, even skunks. They're not much fun in releasing them.
/ Ground Hogs #18
Yeah, I caught a skunk in one a few years ago. What made it worse was that the trap was in a somewhat confined space where moving it was a little tricky. Wife was a little more daring than I, and was able to release it without any problems.
Woodchucks are really stupid. Had a mother and 2 young ones one year, caught all 3 within a day with the trap in the same place (with the same limp piece of lettuce as bait).
2) I buy these things called gopher gassers, available on amazon or my nearest country store. Using them requires finding all the holes (the hardest part) and they need to be home. They will almost always be home in the middle of a hot day. Then you fill in all the holes with rocks and dirt except 1. You get rocks and dirt ready for the last hole. Light it, throw it in fuse end first and fill in the hole with rocks and dirt quick as you can. These things have never failed for me. They may not be legal where you are.
I've gassed them with a hose off a tailpipe (assuming you can get a vehicle near one of the holes). 2nd entrance was under a shed where I couldn't get at it, but didn't need to. At least I assume I gassed it...after one session never saw it again.
Some rodents you can pee around the hole(s) and the scent will repel them, but that doesn't seem to work with woodchucks.
I don't have the patience to sit with a .22 and wait for it to show, especially since they're most active at dawn and dusk when the mosquitoes are bad.
/ Ground Hogs #19
If they are in a place where you can't shoot them, try scattering some dog hair around the area. My daughter is a dog groomer so I get her to collect up some bags of dog hair and put it in the areas that the groundhogs like to dig. It'd not as permanent a fix as shooting them, but it works.
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
2016 Ford F-150 4wd 4 Door (A63118)
2016 Ford F-150...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
Mini Excavator Attachments (A64047)
Mini Excavator...
18ft Gooseneck Utility Trailer (A64047)
18ft Gooseneck...
