Am I nutz?
/ Am I nutz? #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Lie if you must.
I have a concrete mixer idea. Skip all the rotating parts.
Get an out of date large propane tank or other tank the right size. Could be a 50-gallon drum.
Weld to it a frame to allow it to be gripped firmly in a grapple - or- bolted to the bucket. Maybe the latter is smarter. The orientation of the tank is with the long axis of the tank in line with the front to back axis of the tractor.
Then rig it so you can open it from the outboard end; preferably with a hinge so the cover doesn't fly off.
Then tilt it up with the bucket or grapple and fill with concrete aggregate and water, close up and get in the tractor to operate the FEL tilt & dump function tilting it back and forth to mix, then drive to the pour site and dump.
/ Am I nutz? #3
Good idea but I think you'd also need baffles of some type that would cause the concrete to actually mix/flop over on itself as well slosh back and forth. Sorta like folding cake batter...'ya know when you mix ur cakes :), you take the bottom batter and bring it up to the top. I'm having a hard time to explain what I'm getting at but you want the mixture to keep flipping top to bottom so the heavy aggregates are brought to the top and have to fall thru the lighter to the bottom. Just my thoughts...............Mike
/ Am I nutz? #4
I suspect it would be easier to Fab a drum carrier for the 3pt hitch on a pivot similar to a pond scoop mechanism. People have converted drums to mixers by cutting and rewelding part of the sidewall into a lip. if going this far, there may be some way to agitate the mix with the pto?
/ Am I nutz? #7
The ACI has a qualification test to pass if you are to be an ACI certified concrete field inspector. In that test they have a device to test the entrained air within the concrete. It's called a Rollometer. Its essentially two cylinders with measured amounts of concrete, water and alcohol that you either roll / shake to mix the ingredients and read the removed entrained air. You have to mix thoroughly and have no stuck concrete in the housing. It is nearly impossible. And therefore the rollometer is rarely ever used.
Your idea is similar. It might work depending on how hard you shake. But the violence needed may rip your loader to shreds. Just like my shoulder.
/ Am I nutz? #8
I'd rather do the 3 point thing, add rubber wheels that can touch the ground to turn the barrel like a push mower as you drive.
/ Am I nutz?
all well and good, but you are talking to a guy who has mixed concrete all his life with a honkin huge hoe or a shovel and I know darn well I have never put that much energy (as you describe) into a mix and all my concrete has managed to serve my needs perfectly well (emphasis on "my needs"). And I ain't ne'er used nor heard of no rologizmodo gadget and wouldn't know one if it sat in my lap and demanded child-support.
Mind you, I ain't ne'er built no overpasses or highway construction jobs or skyscrapers and I suspect if that I showed up at such a job with a 47 HP Kioti tractor and a 50-gallon drum to mix concrete that they'd show me the exit, right quick.
I kind of suspect a homespun shake-n-bake mixer would do an even better job than my hoe or shovel. And I can only apply as much force as the machine will produce. Koiti does not have a fast dump feature (DARN). So it'll just slosh it back and forth.
/ Am I nutz? #11
add an auger so that it will properly mix. the up / down of the loader / grapple would be insufficient
creative idea
/ Am I nutz? #12
Maybe you need a honkin hoe or shovel in the barrel? I know you were looking for no moving parts but what about this:
- You mix the concrete in an open top barrel with a large (but not too large) post hole digger off of the three point hitch. Once mixed, pick-up with loader and dump where you want.
/ Am I nutz? #13
The strength of concrete is inversely proportional to the amount of water added to the mix.
To make a mix that would blend correctly with the front end loader would make a very soupy thus weak mix.
Something like this would be much better. This would give you the correct mixture to produce a quality concrete mix.
/ Am I nutz?
That might work !!! have to remove the digging tip from the auger and replace with something soft like HDPE.
put the barrel on wheels so it can be moved around to get all of it.
/ Am I nutz? #15
As to the title or the OPs question … if you have to ask, do you really wanna know 😁
I doubt that you would get adequate mixing just sloshing it around in your loader. I have had problems with getting it to blend in an actual mixer.
/ Am I nutz? #16
Mixer drum on an old differential input, at an angle. Hitch to tow it. Make a way to dump it.
Bruce
/ Am I nutz? #17
Lie if you must.
I've been trying to come up with a design similar to what you describe for years. Thanks for your ideas.
/ Am I nutz?
Do I really wanna know?
Hmmm
Let me think on that a bit.
If it were possible to know - - - Does one want to know the exact time and circumstances of the horrible things that will happen to one; things that cannot be avoided.
Hmmm.
Am I nutz?
Well I guess the most profound thing I can say is
Sometimes you feel like a nut
/ Am I nutz? #19
I like it! put baffles inside, have it roll directly (like a regular roller) on the ground and have doors that open to dump it out. Have it mounted to your lift arms so you can back up to whatever you want to pour. I might have to do that! I have some plastic drums...
/ Am I nutz? #20
If you start cutting a Propane tank, it won't matter anymore. Rent a mixer if you need one!
2012 Kubota M108S 108HP 4WD Agricultural Tractor with Bush Hog 2615L1 15ft. Rotary Brush Cutter (A59228)
2012 Kubota M108S...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
