Stihl blower spark arrestor.
/ Stihl blower spark arrestor. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I have a Stihl leaf blower BG 86 that is 8 years old, maybe 100 to 200 hours on it. Today it wouldn’t start. It seemed like a sudden problem, it ran fine last time, although when you go back and look at the past maybe it wasn’t running quite right. I bought a new spark plug, in tank fuel filter and air filter. No help. My gut reaction was no spark, I pulled the plug and tried to hold it near the head and sometimes got spark but not much. It’s very hard to do this while trying to pull the start chord and get good contact with the plug.
My gut reaction was wrong. After messing with the on off switch I pulled the spark arrestor and it started right up. The spark arrestor was badly plugged up. With mineral spirits, a brass brush and air it cleaned up. Reinstalled it and it’s all good. The bad part is I saw a YouTube video on this very problem but dismissed it at first because I thought the problem was sudden. The spark arrestor is about the size of a spark plug and has a fine mesh screen. I show a picture of it and where it installs in the muffler.
/ Stihl blower spark arrestor. #2
Yep, that's the usual culpritl One forgets about the Spark Arrestor since the machine (BG86) works so well from day to day. I just saw the same thing on my FS 90 Stirhl Brush Cutter.
Cheers,
Mike
/ Stihl blower spark arrestor. #3
Interesting information. Thanks for sharing. One more trick to keep in mind.
I’ve torn into them on Stihl chainsaws, totally different and less likely to clog. The pic above is before I cleaned it.
/ Stihl blower spark arrestor. #5
The one on my BR430 did the same thing. It's a tiny conical screen, looks like a design that will clog easily. I use a propane torch to burn them clean.
/ Stihl blower spark arrestor. #6
I am wondering if you can take the screen off the threaded piece and toss it and just screw it back in. I eliminated the screen on my echo trimmer, and both my chainsaws.
I’m sure you could get rid of the arrestor but I’d just as soon leave it intact even though we don’t have a lot of fires here.
/ Stihl blower spark arrestor. #8
My buddy just went through this with his Stihl blower. I first thought his issue was the carb or filter. Nope, this was the culprit.
/ Stihl blower spark arrestor. #9
Some dirt dobber bug likes to pack the Stihl bower exhaust port every summer. After cleaning runs fine. Think it’s over 25 years old.
/ Stihl blower spark arrestor. #10
Not only Stihl. My 20 year old Yamaha generator wasn't running like it should. Checked the manual on plug gap and so forth and seen the spark arrestor maintenance schedule. The thing was almost plugged. Runs like it should now.
/ Stihl blower spark arrestor. #11
That's good info. I'll try to remember it.
I would have never suspected a spark arrestor to cause a problem.
I thought they just rusted and fell apart.
/ Stihl blower spark arrestor. #12
like bmg88201 said, i got rid of the screen on the Stihls that require it most, problem solved. wouldn't worry about it unless in fire hazardous conditions.
/ Stihl blower spark arrestor. #13
I've got a Stihl SR200 sprayer. I need to propane torch the spark arrestor about once a month. I can now tell when I need to. I spray about 30 fruit trees once a week. I read somewhere that the more WOT use the less clogging of the arrestor? I just can't run WOT all the time. Torching it takes about 1 minute. I also occasionally torch the arrestor on my wife's weedwhacker. Using one gallon 93 octane with 2.6oz Stihl Platinum oil.
/ Stihl blower spark arrestor. #15
Has anyone (other than the Stihl lawyer) ever heard of a chain saw that started a fire from throwing sparks?
/ Stihl blower spark arrestor. #17
Save the solvents and burn it out with a torch.
/ Stihl blower spark arrestor. #19
I see some North Easterners willing to play fast and loose with sparks in the woods. Here in the west, we lose whole summers to just the choking smoke from fires that are hundreds or more miles away - and worse. Things that create spark in these parts are taken seriously, by more than lawyers and bureaucrats.
/ Stihl blower spark arrestor. #20
Yep... start a fire due to no spark arrestor is a serious crime in the fire prone West.
Back in 1980 the first brush cutter was awesome until it wasn't.
Found the spark arrestor plugged and clean it was good to go.
I think the premium/ultra two stroke that Stihl offers must minimize soot because not nearly as big a problem in later years.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
UNUSED KIVEL MINI SKID STEER HITCH ADAPTER PLATE (A62130)
UNUSED KIVEL MINI...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
WOODS TBW144 TURF BATWING ROTARY MOWER (A62130)
WOODS TBW144 TURF...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
