FE35 Goldbelly Petrol
/ FE35 Goldbelly Petrol #1
nambuat
Ferguson FE35 Goldbelly
My FE35 has gone on strike after I changed the original ignition switch to a universal ignition switch. Main reason I did this was because I didn't have a key for the original switch and had to use a screwdriver to start her. When I turn the key now she fires but won't run. Any help please?
/ FE35 Goldbelly Petrol #2
When you twist the switch is there a spring loaded part of the switch that goes to the start circuit and when you release it, goes to the run position? If so, you need to connect the ignition system to the run position as well as the start position.
Great! Thanks...I'll have a gander at it tomorrow
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
UNUSED KUBOTA B2366 PIN ON QUICK ATTACH (A62130)
UNUSED KUBOTA...
2021 John Deere 6120M Tractor (A63109)
2021 John Deere...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
EZ-GO Golf Cart (A61166)
EZ-GO Golf Cart...
