Anyone ever drove over plywood on soft grass or mud w their tractor?
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #11
Have you checked around for the real thing from land clearing/logging companies?
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #12
OP, can you plan ahead and put some 2x4's under the OSB and have them stick past the edges to allow getting a chain under them to lift the up? Just wondering if that would break the suction force. Jon
I think i would use plywood not osb. But yes i probably could do that. That’s a good idea.
I’m thinking i might cut the large sheets into 4x4 or 2x4 pieces.
No i haven’t. Tomorrow i might call around. I am expecting it to be hard to find or expensive to rent.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #15
Yeah, missed the plywood vs OSB. Jon
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #16
What are you trying to do with the tractor that you need to cross the mud? Would it be more effective to spread some stone if this is to become a repeated operation? Digging a drainage ditch an option?
Rental stores have rubber mats for rent but they are very heavy and hard to move.
Trying to move mats with a TLB will be difficult at best. An mini ex would allow you to pick up the mat behind you and move it to the front of you.
If this is a one time thing you might be able to cut some brush or tree branches and "pave the road" by laying them across your pathway.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #17
I've used plywood to cross a golf course section with a skid steer takes a little while moving the boards but it worked fine to keep from damaging green.
Also used plywood to get 5th wheel trailers on/off the beach.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #18
I've used plywood when using my bobcat with pallet forks to move a 12x20' shed on tiny 8" harbor freight wheels. I was leapfrogging the same 4 pieces of plywood. This was before plywood costs what it does now, of course. I keep a couple spare scrap pieces of plywood around though. I also moved my 3500lb scissor lift across the yard on plywood, and that has even smaller tires.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #19
I haven't tried it, but would horse stall mats work? Pretty heavy.
I have to dig a trench. But the area is soupy in spots. Its part of a field. I hear you on the mini ex. That is the best solution, mini ex with bog mat but i don’t have either. We were out there w the tractor yesterday and it did decent enough, just kind of sank in a few of these spots which seem like plywood may be able to assist with.
These were what i was originally looking at. I don’t know if they would. Someone on FB said they tried them in mud and they didn’t work, but plywood did. I never considered plywood but once i started researching it seems like a potentially better option. About the same price as the stall mat, but it’s 4x8 vs 4x6 and it’s got the extra rigidity.
I also learned that a lot of landscaping companies use plywood as ground protection.
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
2019 Ford F-450 4x4 Crew Cab Gooseneck Flatbed Truck (A49461)
2019 Ford F-450...
