PT-425 50 Hour Service Issues
/ PT-425 50 Hour Service Issues #1
BigDaddyEureka
Deere, Power-Trac
Hi all,
So I'm doing the 50 hour service...changed the engine oil and filter, the air filter, lubed most all of the chassis points, and lubed up all the linkages good, and then.....
1) We reached the @#^* hydraulic oil filter. It's pure eeeeeeevvvviiiilllll. None of my wrenches will move it, and there's basically almost no room to turn it once you've got good contact. Rubber gloves and turning results in popping my shoulder off the bone (old farming injury, it happens sometimes) but no motion. I could drive a screwdriver or an awl through it, but I think it would just result in jagged, torn filter housing and still be stuck. Can't remove the filter base because even if I removed the outlet hose, the inlet from the tank is a union that can only rotate with the filter off the housing. I'm sure it went together just fine in the factory...
2) Removed the center covers to reach the front pivot grease point and discovered....no zirc. There's a metal plate like for the rear one, but the location where the zirc should be has no zirc....and no threads for it....just a blind hole! Upon closer inspection I'm not convinced the rear one really works right either (although there is a zirc there and I've used it before). Up front there's what appears to be a blind hole that isn't tapped, and looks like it SHOULD have a zirc...but nada. For now I've lubed both ends of that link with white lithium I can spray into the joint directly and it sounds MUCH better, but still that's not really what I wanted to do.
Ideas anyone? I've got a few but no options I really like...
/ PT-425 50 Hour Service Issues #2
Congratulations on getting most of the way through the service...yeah, the filters are hard. It isn't you.
I mostly change my hydraulic filter with a 1/2" drive strap wrench on a 30" breaker bar. It just turns it without crushing the filter if I try to ensure that the top of the strap is right at the edge of the filter mount. Once it starts to loosen, I get the strap out of the way to keep it clean and unscrew it by hand.
Someone, I think it was @MossRoad, put me on to putting an empty gallon size ziplock under the filter before starting the removal process. It catches the oil that leaks out and provides a clean way to get the filter out without dripping oil everywhere.
When you install the new filter you want to get it on really tight to prevent air leaks. So yes, the filter are on hard, and then as a result they are hard to undo. I have 24" serrated channel lock pliers as back up, though they do make dedicated oil filter wrenches that size and larger. The problem I have and you probably also have is that there isn't much room. I have a 36" 3/4" breaker bar on standby, but I have never used it.
On #2, my first instinct is to call Terry and see what he has to say. My second thought involves drilling a hole to tap the zerk, and large enough to provide future access to the zerk, but I am not sure that you want to be drilling holes there.
All the best,
Peter
/ PT-425 50 Hour Service Issues #3
Yes, once I get the hydraulic filter cracked loose, I put a zip lock bag around it and then unscrew it so any drips go in the bag. I also put a layer of paper towels under that area before I start to catch any drips.
Stuck filters are no fun. Have you tried tightening it some more before loosening it? Sometimes that works. One, because it breaks some tension in the threads, and two, because I frequently have problems with righty-tighty lefty-loosey when I'm looking at something from the opposite side! 🤣
If there's a hole with no zerk in it, you gotta wonder if someone missed something at the factory, of if it's been discontinued. My 2021 manual said there were zerks in locations that I could not find. A phone call to Terry and they stopped putting them in that location. So check with Terry to be sure.
You might be able to use a push-type grease gun in the hole if there's no zerk, until you decide if you want to tap it for a zerk.
Or you can get press-in zerks that just press into the hole, no threads needed.
/ PT-425 50 Hour Service Issues #4
My PT018 does not have room for the front fitting on that center link with the cover on. PT intended to move the rear fitting to the front, grease, then back again.
I don't think spraying white grease into the hole will do what needs to be done.
Make sure you have the bleeding process procedure in your mind before you call Terry, you might have more questions. I remove the spark plugs so the engine turns over easily when priming the new filter (I prefill the filter so I don't have to crank the engine as long. If you want to do this, make sure you only fill the filter through the side holes and not the center hole)
/ PT-425 50 Hour Service Issues #7
The idea is to only have clean filtered oil coming out of the filter.
The inside is the filtered side. Fresh oil has been known to have debris in it. If you just fill via the outer holes, then the oil that goes to the charge pump will have been filtered.
It is a good idea for all filters in my book.
There are some non-spin on hydraulic cartridge filters for which the flow is inside out rather than outside in. You can usually tell because the metal support screen or mesh is on the outside of the filter. If in doubt, read the manual...
All the best,
Peter
/ PT-425 50 Hour Service Issues #8
Maybe I'm reading this wrong, but are you waiting to lube every 50 hours?
Oh no, I've been doing other regular lube every 10 hours or fewer. At 50 hours is the first "big service" for the hydraulic oil filter, the forward center pivot, etc.
I decided to change the engine air filters as well as the oil and filter anyway, even though Koehler says you can go 100 between changes. I figure oil and filters are cheap and engines are expensive, so as long as I was in for the big service I'd do the whole enchilada.
Once the "required" stuff is done, I have a couple of upgrades I plan to do too. More on those later once we get the other work done...
Thank you everyone for the input! Ordered another filter wrench that may help.
The idea I had that I didn't voice right off is to "work it hot" by changing the hydro filter with the oil hot enough to turn on the cooler fan. Not my idea of a good time, but sometimes the hot oil causes things to expand and loosen up (which is often the source of many leaks too). I could maybe just break it loose hot, then wait for it to cool off before taking it off the whole way. Don't really want to cook myself if possible!
/ PT-425 50 Hour Service Issues #11
I can't really recommend the "work it hot" strategy with the hydraulic filter. It is too awkward and the oil too hot, for me at least.
I could be wrong, but I believe that zerk on the "bow-tie" or "dog bone" connecting the front and year is in principle an 8 hour service item. I can recommend Lock-N-Lube connectors on your grease gun if you ever do get a zerk in there...I use my battery powered drill to remove and replace the bolts that hold the cover on as it is easy to set the torque on the bolts and it is quick.
All the best,
Peter
Huh. My manual shows the rear of the dog bone getting lubed every 8 hours, but the front (where you have to remove the covers) is listed as a 50 hour item.
That said, I can DEFINITELY see why one would be much better off doing both at 8.
/ PT-425 50 Hour Service Issues #14
I ended up removing the small cover over the front one as I'm too lazy to remove 4 bolts so often. I also removed the two tunnel covers on the sides so I could get to my 3 zerks on my treadle. And I also removed the top tunnel cover, as leaves and debris would build up in there. So, basically, all the tunnel covers are sitting in the garage. No I just leaf blower it out after use. A lot easier.
/ PT-425 50 Hour Service Issues #16
But then I gotta find a new place for my cupholder... :LOL:
OK 🤣
Gotta have that.
Then you might try this. A 1" bi-metal hole saw right over the zerk area.
Been so busy I haven't had time to write!
FINALLY got the filter off thanks to @ponytug advice and a newer, larger, beterrer strap wrench with a 1/2" drive with a 36" breaker bar. Result: an utterly crushed filter later and....we're good! :cool: (y)
Of course, then you need to get the filter back ON and that's a trip and a half. Apparently they don't have gravity at PowerTrac central or something? Best bet was to weasel a hand UNDER the filter and support that with your fingertips, while rotating with the fingertips of the other hand. Once threaded nice and straight, tighten up appropriately.
Serviceability on that is a solid 0 / 10 - would not recommend. Gonna have to find a filter like the one I used on the engine with the nut on the bottom next time...
/ PT-425 50 Hour Service Issues #19
Congratulations! Great to hear the follow up. That is a nice looking strap wrench!
My general tip on the strap wrench is to keep it as high as possible on the filter. My first couple were pretty mangled until I had it sorted out. Practice makes... well, better for sure.
Funnily enough, the finger tip method for starting the new filter is what I use as well, and I know that there is a ton more room in my tractor.
Terry tip #1: Once you have your tractor running for a bit, check for foaming by opening the hydraulic fill opening with the engine running and look for tiny bubbles. If you see any, the filter isn't on tight enough. Terry's tip #2 was to clean the outside of the new filter, and then look for dust accumulating on the outside of the filter filter. Apparently, not having the filter on tightly enough apparently manages to spray or push oil out of the filter rim on to the filter, where it attracts dust.
All the best,
Peter
2014 Aerway Aerator (A55973)
2014 Aerway...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
Pan Rack (A60352)
Pan Rack (A60352)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
