Bleeding air from NH TC30 fuel line
/ Bleeding air from NH TC30 fuel line #1
Jerry Lehman
Terre Haute, IN
New Holland TC 35 & TC40D
Had an attack of stupidity and ran my TC 30 empty. Didn't have an owners manual as I purechased it at an auction. If you run yours dry bleeding is simple. Fill the top mounted fuel tank which applies pressure to fuel line. Located on top of the injector pump is a hex head bolt. Open it about 4 turns. There is a bleed hole in the screw. The pressure of the oil in the tank will bubble out the air. Wait another minute until oil slowly ozzes out. Close bleed screw and start. What I thought would be a bear to solve was simple, thanks to New Holland.
Jerry, Terre Haute, IN
/ Bleeding air from NH TC30 fuel line #2
Thanks Jerry! Since I found this post really useful, I'll add a bit more for the next person who needs it. The bolt is a 13mm, and you'll need either a box-end wrench, or, if you come at it from the top, a socket with a flex connector on the socket end, and an extension. It's the bolt on top of the banjo connector for the fuel line. Don't worry, it won't loosen your fuel line, because the body it screws into is the part that clamps the banjo fitting & crush washers. Picture below.
/ Bleeding air from NH TC30 fuel line #3
... Fill the top mounted fuel tank which applies pressure to fuel line. Located on top of the injector pump is a hex head bolt. Open it about 4 turns. There is a bleed hole in the screw. The pressure of the oil in the tank will bubble out the air. Wait another minute until oil slowly ozzes out. Close bleed screw and start. What I thought would be a bear to solve was simple, thanks to New Holland.
Thank you for the details. That was very helpful for me after changing the fuel filter. Although I left the housing loose and let fuel fill up the bowl, that wasn't good enough. I'm back up running again! 🤗
/ Bleeding air from NH TC30 fuel line #4
Thank you for the addition details and picture. Very helpful!
/ Bleeding air from NH TC30 fuel line #5
You could also crank it with an injection line open until the battery is almost dead because you trusted the fuel gauge to read accurately, then put fuel in it. Then charge the battery and start over....but to each there own. Lol
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
2021 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A60352)
Kubota K7874 18in...
HYSTER 50 FORTIS STRAIGHT MAST FORKLIFT (A59823)
HYSTER 50 FORTIS...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
