Tiller Can anyone help me ID this Tillers Maker / Model
   / Can anyone help me ID this Tillers Maker / Model #1
Gotrek
Simplicity Powermax 9020
I think the original color is orange. I've looked at Allis, Kubota pictures and haven't found it yet so thought some of you might enjoy helping me out :) It's about 5feet wide. Came with my New holland TZ24DA.
I want to see if I can find a manual /parts diagram to give it proper TLC and adjust it.
   / Can anyone help me ID this Tillers Maker / Model #2
Looks very much homemade from a donor tiller of yester years. Even the 3PT is generic enough with tiny holes and bolts.
The short shafts say it's a 1970s Asian tiller.
Are you looking to replace the tines or bearings or drive chain/belt ? Or all the above?
Bearings are ok, some tines are missing, I want to know how to adjust the chain drive tensionner and what kind of oil it might use/need.
Also the slip clutch (assuming it has one) seems too loose and it's loosing power in loose soil that I feel it should be able to power through
It's super beefy and boderline too heavy for my New holland so I rarely use it but figured I'd give it a paint job and at least try to give it a bit of love. The PO did 0 maintenance on the tractor and implements I got
Took the top off. No slip clutch, took the side off. Full of grease and tentionned properly. So I’ll just leave it alone and enjoy it.
Guess the tiller stopping unde load is my underpowered tractors safety feature so it doesn’t grenade itself lol. Joking aside guess the pto clutch might be worn out or I’m not getting proper pressure I have a service manual for a shibaura sx24 hopefully some clues in there.
Rooster Weathervane (A55853)
Rooster...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
