sesame row planter and header for combine harvester
   / sesame row planter and header for combine harvester #1
omran mubarak
khartoum,khartoum
massy
Good morning, dears.
I'm planning to plant sesame using a non-shattering variety, so i supposed to arrange for planting and i wonder if using a row crop planter would be beneficiary otherwise, I should use a seed drill, the second thing that discomforts me is could i use a pneumatic planter for sesame seeds, because we need to have a specific population with specific distance between lines and equally in-line distance.
The second matter is harvesting sesame with combine harvester does it need a special header for the combine harvested because this crop will have a high yield since it will be irrigated using a pivot irrigation system.
   / sesame row planter and header for combine harvester #2
Salaam Alaikum Omran Mubarak,
My brother, the best way to begin your journey is to visit the San Angelo web page of Texas A+M University.
www.sanangelo.tamu.edu
As far as a planter for sesame seed I would contact the Monosem equipment dealer in Zaire for a planter; sales@carrotech.za
A grain header will work well for harvesting sesame seed you just have to examine which machine to buy.
KUBOTA manufactures small track drive combines that work in irrigated acreage to harvest rice and other crops.
www.thesparepartshop.com
I appreciate your help Leonz
Waiting for you reply regarding monosem planters.
Thank you for your support again
   / sesame row planter and header for combine harvester #4
The folks at Carrotech.co.za build the Monosem planters sold on
the continent for the MONOSEM Company.
There are many manufacturers of grain drills. You will have to
decide whether a row planter or a grain drill will work best for
your entire cropping needs. A row planter will plant many row
crops like corn, sunflowers, soybeans, sorghum etc., and a grain
drill will plant many fine grain seeds.
You will have to decide between a standard grain drill or a row
planter for the sesame seed crop.
investing in a small row planter and small grain drill will let you
plant multiple crops when planting using a rotating crop plan.
It will take longer to do but you will have the flexibility to plant
multiple crops if you have more than one center pivot field to grow
field crops on.
You can request information about the many models of monosem
planters from Carrotech.co.za
field crops on.
Thank you very much for your valuable information.
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2019 Deere 35G (A53317)
2019 Deere 35G...
2016 JLG 20MVL 19ft Aerial Platform Lift (A55851)
2016 JLG 20MVL...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
23091 (A55758)
23091 (A55758)
CAT 420D IT (A47477)
