slingworks
Member
- Joined
- Jun 4, 2022
- Messages
- 30
- Tractor
- Zetor 5211 Ford 5000
Ok, I am a little puzzled here....
I have a Zetor 5211, one of the last commie built tractors. Runs great. Very low hours. I replaced all the brake/clutch/master cylinders etc when I bought it 10 years ago.
Now, lately it's acting up and I'm puzzled. The Clutch works then doesn't work. It will work just fine, engaging/disengaging etc and then on some random note when you press the clutch in, it wont engage when you let the clutch out. It's as though you're holding the clutch pedal down. If I let it sit for a while and try again it works just fine. No slippage. No way it could be worn out (low hours). All hydraulics work great that control it...
PTO works fine as well as the lift when I can't get the tractor to move. PTO clutch appears to work just fine.
Only thing I could think of is maybe the disc is 'binding" on the input shaft somehow? It's a dual clutch tractor....
I do keep the TO bearing lubed through the little inspection port as required....
Any thoughts?
Any thoughts?
