etpm
- Joined
- Jun 30, 2021
- Messages
- 2,408
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Today I took apart the spool valve on the power steering cylinder I bought for my Yanmar YM2310. It needs, in my opinion, a piece welded into the slot in the end of the spool to make it stronger. When I took it apart the o-ring on the spool was damaged and there was rubber debris in the valve body and the spool grooves. So it's a good thing I took the spool out. The valve and cylinder are new and have never been used. I felt inside the valve body and could not find any sharp edges that would tear an o-ring so I'm thinking that the oil used for assembly was just too thin and let the o-ring catch and tear. I would like to use some sort of assembly lube or grease when I put the spool back in. I can't imagine that a tiny amount of grease or 90 weight oil or something similar would cause any problems but I don't know. Anybody here know?
Also, even though I have made plenty of spools and valve bodies in my long career as a machinist I have only assembled a few. The lands on the spools always have sharp edges after being ground and these edges were never broken on the spools we made. Every spool I have ever seen is made this way, and the spool in the valve I took apart today is no different. Anyway, the sharp edges makes assembly a little fussy because the sharp edges of the spools could catch in the bores of the valve bodies when the spool is first being inserted. This could of course damage the valve body and cause, or could cause, leakage. So, I figure the edges of the lands on the spools are left sharp for some reason besides saving a little money by not taking time to break the edges. Is that right? The edges need to be sharp? Maybe this makes the metering work better?
Thanks,
Eric
Thanks,
Eric
