My Tractor Mechanic is not happy
   / My Tractor Mechanic is not happy #1
Mitsubishi MT2001D
I may have bought a 1955 Oliver Super 55 with four implements, delivered, for $2,800.
My mechanic is rolling his eyes because it is elderly and it is gas. But he was at his folks' place or wheat harvest,
I was unsupervised!!!
Is he going to be right in the long run? Did I want a diesel??
   / My Tractor Mechanic is not happy #2
It depends on your intended uses for the tractor.
   / My Tractor Mechanic is not happy #3
I had a gas Oli. It was a fine tractor. It used more fuel than a diesel would. Probably didn't have the same torque characteristics as a diesel.
I would prefer a diesel, but, if I only had one tractor, and no other diesel, I would not be ashamed to own a gas tractor, they start easier in the cold too.
Best,
ed
It is to be the dedicated bush mower tractor. I have a 24hp 4wd Mitsubishi with a F/E loader to do everything else. I just HATE dealing with the mowing deck!!!
Best,
ed
So just to mow the pastures, I am good?? Have a diesel with a f/e loader already
   / My Tractor Mechanic is not happy #7
My first tractor was a 1959 Farmall Cub. I didn't know what I wanted and a friend of mine said this was a good place to start. I loved that tractor and wish I still had it because the $1800 I sold it for is long gone.
It put out a (massive) 12 HP but the machine was incredible when you pushed it a little. I would skid 25' pine logs with it's 2 point hitch and it didn't miss a beat. It was gas and incredibly reliable.
   / My Tractor Mechanic is not happy #9
I think the old Oliver is more than up to pulling a rotary cutter. You should have no problem for that purpose.
   / My Tractor Mechanic is not happy #10
Oliver Super 55 Power
Drawbar (claimed):23.3 hp
17.4 kW
PTO (claimed):32.65 hp
24.3 kW
Drawbar (tested):29.60 hp
22.1 kW
Belt (tested):34.39 hp
25.6 kW
Mechanical
Chassis:4x2 2WD
Brakes:mechanical disc
Open operator station.
Transmission:6-speed unsychronized gear
Dimensions
Length:120 inches
304 cm
Height:71 inches
180 cm
Operating weight:3,400 lbs
1542 kg
Ballasted weight:5,500 lbs
2494 kg
Front tread:48 to 76 inches
121 to 193 cm
Rear tread:48 to 76 inches
121 to 193 cm
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
1996 Ingersoll-Rand VR642C (A47477)
1996...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
More info coming soon! (A55851)
More info coming...
