Mitsubishi D1650 4x4, loader - need filter/strainer
   / Mitsubishi D1650 4x4, loader - need filter/strainer #1
pacer1980
Member
Greenwood La USA
Kubota BX25D Mitsubishi D1650
As title sez, got this little d1650 with FEL (that works great!) as does the rest of tractor, but 3 point wont work. Decided to ck the hyd filter and it was a pretty big mess, not only clogged but coming apart .... and.... I cant find one ANYWHERE!! All I can come up with are spin on oil type filters.
The pic show its status - its 5 1/2" long and 1 1/2" diameter. That end piece is coming apart also - figure I'll have to 'improvise' on it, but would really like to find a replacement
! That screen is really fine mesh brass an its just crumbling. If I could find something similar, I could wrap it around myself, but no idea on a suitable .... mesh. Just really would like to find a replacement....
Anybody???
   / Mitsubishi D1650 4x4, loader - need filter/strainer #2
Perhaps a 'last ditch' fix but that filter screen is brass.
You could always solder a 'patch' over the missing area.
My CUT has been running for 8-10 years with that same 'fix'.
A 'patch' will simply reduce the working area by a small amount but still do its job.
Your suggestion is exactly what I'm thinking. Prowled around on McMaster this morning and of course they had about a dozen types of mesh, in fact so many I couldnt figure out just what they did! Finally settled on a stainless piece 12/12" and got it coming. Now to figure the end piece, my first thought is to get an O ring about that size....
Did you try Valley Power
I will give them a try first thing in the morn, wasnt familar with them .... thanks for the link, they will probably be needed again -- at some point!
I did contact Valley and the guy (really friendly!) said that they may have one but if not they could re-wrap mine. By this time I had been prowling the web for mesh and - Of course! - Mcmaster Carr had several grades of mesh and I had chosen one - guessed at one! - a 12x12" stainless steel. So I put the guy off at Valley, but certainly added his web site to my list....
Well it came in a couple days ago and with some fiddling/cussing I made up a rather nice filter. Cut it to size and put a couple tie wraps on for a starter, this allowed me to work the end 'caps' on, then using small safety wire and started snugging it up - tied it at 6 points and removed the tie wraps ---- and wow! Looked great!
Installed it and every thing works great! Thanks guys, Bill
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A56138)
2014 INTERNATIONAL...
2001 Dodge Ram 3500 4X4 Flatbed Truck, VIN # 1B7MF33651J565664 (A54865)
2001 Dodge Ram...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2006 International 9400i (A55302)
2006 International...
NEW HOLLAND LX885 SKID STEER (A52706)
NEW HOLLAND LX885...
