JD 447 backhoe , stabilizer issue
/ JD 447 backhoe , stabilizer issue #1
Leaks52
Hollowville, NY
JD 3320
Hi all , I have aJD 447 backhoe on a JD3320, one of the stabilizer legs loses pressure during operation. It isn’t leaking externally. Any thoughts on this would be appreciated.
Thanks
/ JD 447 backhoe , stabilizer issue #2
Thanks
If the cylinder is leaking down when extended and there are no external leaks then it is likely the control valve that is leaking internally.
/ JD 447 backhoe , stabilizer issue #3
Control valve
Kinda thought the same thing. Thanks for the reply !!
ALUMINUM HEADACHE RACK (A60736)
ALUMINUM HEADACHE...
Clark C500-YS80 Forklift (A61166)
Clark C500-YS80...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
2021 KUBOTA KX033-4 EXCAVATOR (A62129)
2021 KUBOTA...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
