Need older tractor recommendations for round baling.
/ Need older tractor recommendations for round baling. #1
FarmerRancher
Haskell,OK
Kubota L2800
I currently own a Kubota L2800, which obviously doesn't have enough horsepower for round baling. My partner in the round baling equipment has a JD 4640 that I can use to run the equipment that we own together. But, I just don't like borrowing and possibly breaking somebody else's stuff. So, I'm looking for a "new to me" tractor to handle the mowing, raking, baling and stacking. Budget is limited, so the best equipment I can get for the price is the objective with lowest used price and doing the job being my main prerequisites. Not really looking to buy a machine thats not running. I have enough to do with getting the baler completely refurbished and I'm a one man show.
I'll be running a disk mower, rake (no model number yet) and a Vermeer 605H round baler from around the 80's.
Might be opening a can of worms, but anyone know some good models for this job that I might be able to find used?
/ Need older tractor recommendations for round baling. #2
maybe a bit big but not a bad ride.
budget? what is the terrain like? do you have to worry about it being wet? can you live with stacking with another machine? how much hay do you make a year?
with older stuff its more important to get something that has been maintained than to find a specific model.
/ Need older tractor recommendations for round baling. #3
A good JD 4020 is what I would be looking for in an open station. But with a canopy and loader. They were one of JD‘s best models.
Terrain is Oklahoma flat where I’ll be baling. Less than 6 foot drop in 1/2 mile. Wet is a problem this year, but not usually. I’d like to be able to stack, but it’s definitely not high on the priority list. Shouldn’t be baling more than about 90 acres, tops. Yield varies greatly. I got 37 bales on 6 acres one year. Havent approached that since, though. Agree completely on the maintenance issue. But, I am blessed to have a neighbor thats a tractor collector and aircraft mechanic. I’ll definitely be getting his input on anything before i actually buy.
/ Need older tractor recommendations for round baling. #5
50-60 hp minimum. Some older tractors don't have sufficient hydraulics to lift v-rakes or baler door. Neighbor had a Farmall 60 and I had to run his rake and baler for him. Farmall didn't have enough flow for newer equipment.
/ Need older tractor recommendations for round baling. #6
1066!
At least that’s the tractor I’m trying to find.
/ Need older tractor recommendations for round baling. #8
I started custom rd baling in '87 with an open station JD 4030 tractor(80 pto hp). After a couple of yrs of breathing in dust I traded for a JD 4240(110 pto hp). In '93 I traded for a JD 4255 that I use for baling up to present.
If anyone rd bales hay that been rained on after being cut you'll be begging for a tractor with a cab with operating AC. I'd look at a JD 30 & up series rowcrop tractor. JD 50 & 55 series utility tractors with factory cabs have too many electrical & hyd problems for my liking.
I personally don't like ""operator inconvience on IHC 06,56,66 & 86 rowcrop tractors"'. I drove my friends IHC 986 for 1/2 day using a 24 ft 3 pt field cultivator. I didn't like the trans shifter,scv or 3 pt controls & location. Therfore I replaced 986 with my 4225 on the field cultivator & chose never to drive the 986 again.
/ Need older tractor recommendations for round baling. #9
I would consider most tractors between 90 and 140 HP.
Myself I'm partial to IH over Deere many people are the other way.
I wouldn't be afraid of any of the major manufactures, IH, Case, Ford, any of the AGCO line or even Deere.
I would also agree I would want a cab and working AC for a haying tractor.
I believe that you can get more value for your dollar on most any compared to Deere.
Myself I never felt operator inconvenience while running an IH. My most desired for your
application would be a big larger it would be the CIH Magnums the 7100 or 7200 even in 2wd drive with that full
18 sp power shift they are durable dependable and a joy to run.
/ Need older tractor recommendations for round baling. #11
The JD 3020 and 4020 are high on my list at this point. Some of my neighbors have also mentioned them. But, im ofan open mind.
How big of bales are you making?
5x5 for myself. I have the original Vermeer manual for the baler and they recommended 60 to 70 hp. They also recommended against too much hp, although i dont recall them saying what too much was.
Just a note to everyone… if i say something, its to the best of my knowledge and ability. So, i will change my opinions on a dime if given a good reason. Im here to learn.
/ Need older tractor recommendations for round baling. #13
Forget any open station tractor, especially with a disc bine because they can throw debris (sticks and such) forward while cutting. No disc bine manufacturer would recommend cutting with an open station tractor. What ever you get. expect to pay top buck for it because pre 4 (older tractors) are commanding premium prices today. 5x5's you need at the bare minimum 60 pto and a dis bine is power intensive as well. I'd be looking it the 80-100 pto bracket, cab tractor with working ac.
Good luck finding one.
/ Need older tractor recommendations for round baling. #14
Think hard on the stacking capability... If you have another machine with a loader. Non-loader tractors are much less cost. Without a loader 2wd is doable. Seems everyone with a single machine wants a loader and MFWD.
/ Need older tractor recommendations for round baling. #15
oh man, if I was doing hay i would have one of these. if its in good shape, its a fantastic deal on a hard to find machine.
/ Need older tractor recommendations for round baling. #16
They are a nice handy tractor for a second unit. Drawbar work is not there strong suit
the transmission generates too much heat and will wear out. That is what shuts most of those down.
/ Need older tractor recommendations for round baling. #17
I guess I'm in the minority here, but I hate to use one of those for hay work. Just not enough gears in an eight speed transmission to be efficient. I've used a Deere 4000 with the syncro range for a lot of acres, and the fifth to sixth gap is just too big, and since it crosses ranges you kinda gotta pick one and stick with it. Just horrible. Power shift would probably be better, but still too few gears. It sounds like a more modern powershift tractor would be out of your budget, so I would really try to find something with a high/low in each gear (or a high/straight/low with the White).
I'm really partial to Fords for hay work. The foot pedal high/low is really convenient, the non-synchronized transmissions are still pretty easy to shift on the fly with, the operator station is way better than the German Deere utilities (Waterloo tractors command stupid high prices for someone on a budget) or any IH, and they tend to get overlooked in the red/green color split so they can get bought pretty reasonable.
Like I said, whatever you decide on, expect to pay a premium price for it.
I guess I'm in a good position. Both of the neighbors I've talked to have offered their tractors (JD 4020 and JD4640) to use until I find a "good deal". Like I said though, the pressure on me to buy comes from myself. I don't like breaking/repairing stuff that belongs to others. On the other hand, I'm not opposed to paying more for a well-maintained machine. My experience is that the further the seller is from technology like eBay and Craiglist, the more sensible the price. So, I'm shopping more by word of mouth and letting all my neighbors know what I'm looking for, as soon as I can figure out exactly what that is. Thanks to all for the input.
Another I've talked to recommended something like that, but it was a different brand... Versatile. But, when I looked at prices for those, most of them were overpowered for my needs and cost a lot more. The ones that seemed within my budget were a LONG ways from Oklahoma. Family issues and ranch demands make travel like that unfeasible.
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2005 DRAGON ROLL-OFF  TRAILER (A60736)
2005 DRAGON...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2022 East...
2018 HINO 338 4X2 22FT CDL REQUIRED BOX TRUCK (A59906)
2018 HINO 338 4X2...
