imatch knock-offs? (JD2305 & RC2048)
/ imatch knock-offs? (JD2305 & RC2048) #1
JCCinOhio
Member
SW Ohio
JD 2305
I have a JD 2305 and am looking at getting a RC2048 rotary cutter.. I looked at the manual for the cutter and it said the imatch is required to 'facilitate driveline length'..
I have no other rear implements... so hate to pay $400 for an imatch. Anyone have luck with any of the spin-offs?
Thanks!
/ imatch knock-offs? (JD2305 & RC2048) #2
These are very simple devices and I think all the cheap quick hitches work OK. I've been using a Harbor Freight QH for over 10 years and it's great. The only issues I've seen are that the hook forging isn't as precise and, in extreme cases, may benefit from a little grinding and the bolts on the adjustable hook my interfere with some implements, requiring an extended hook or link. (This last issue could happen with an imatch also.)
/ imatch knock-offs? (JD2305 & RC2048) #4
Almost 20 years with a Speedco. Painted JD Green and chain boxes added. Has held up just fine, no issues. An occasional shot of lube in the linkages and some black tape round the plastic grips.
/ imatch knock-offs? (JD2305 & RC2048) #5
If you have no other implements, and don't expect to change often, do you need a quick-hitch at all? I have a number of implements, but don't change them all that often and have never found the need for one.
You may have to shorten the driveline, but that's a common practice that's described in many online sources.
Yep.. after talking with the dealer driveline shortening seems the way to go. Picked up a lightly used 2018 RC2048 cutter yesterday at a little over $1k less than a new one..
/ imatch knock-offs? (JD2305 & RC2048) #8
like your chain boxes. do they get in the way of the PTO shaft. I find it is already tight enough getting in there to hook up a shaft without chain boxes but I could really use chain storage.
/ imatch knock-offs? (JD2305 & RC2048) #9
Yea, was thinking about that when I mounted the boxes, so each box is attached via a pair of threaded studs welded to the QC so they could be removed. I find the QH itself is what gets in the way; the two smaller chain boxes are pretty irrelevant.
I wind up laying on my back to connect the PTO shaft. Between the QH, the tractors metal PTO guard, and the rotary cutters plastic PTO housing/guard, sliding underneath is the quickest, most reliable way to ensure the shaft disconnect is indeed fully seated.
My rear PTO is only used a few times each season, so the on-the-back routines is merely annoying. But I do change between ballast box, box blade and straight blade frequently, so QH has been a friend. Often skid trees, so chains boxes have earned their place….
/ imatch knock-offs? (JD2305 & RC2048) #10
Nice work, I assumed they were welded so I though I would ask because like you I find the quick hitch is already in the way when hooking up a shaft
/ imatch knock-offs? (JD2305 & RC2048) #11
/ imatch knock-offs? (JD2305 & RC2048) #12
It's all a matter of how much you want to spend. The imatch is a quality component for $400. I'm sure the Speeco at $300 (and other similar components) are very nice. For me, the Harbor Freight QH, at $129 does everything I need it to.
